3 members (1955 1 Series, Hanks custodian, cmayna), 155 guests, and 0 robots.
Topics128,114
Posts1,056,287
Members48,439
#812786 01/03/2012 2:07 PM
Va. 1952 tags use the 51 plate with just a metal corner, about 1 1/2 inches X 1 1/2 inches, with the 52 on it that u bolt on over the 51. Korean war times saving metal no doubt. DMV will let u tag truck using these odd plates. I bet most people think the owner just did that to change the year on his own!! I also have the county metal tag that was used back in the day. Both will go with the truck when I sell it this spring if the new owner is from Va. I wonder what other states did this or something simular and can u use em today?
'52 3100 "once a Marine, always a Marine!!
New York state had no 1954-specific full-plate. A new vehicle registered in NY in 1954 used a 1953 plate with a small 1954 metal plate that covered the 1953 in the lower right corner. Also, only one plate was used on NY vehicles at that time.
Yes, you can use original Year Of Manufacture plate(s) in NY. It is easy to do (have have plates for three 1954/55 vehicles). The plate(s) must be original paint and the number/code must not now be in use on any other NY plate.
MO is the same way. I think the plates were used from 47 or 48 thru 52 or 53 or so. The Truck tags are red plates with white letters and different color metal year tags. The one on my 51 is yellow w/black writing.
http://farm3.staticflickr.com/2527/5740963414_ac46d31f5a_m.jpg
I have a 1959 Chevrolet with 1959 South Dakota plates. These plates have the small tag on them also.
Bruce
My Trucks
Stuff I Collect
Minnesota did that until they came out with the stickers to change the year. At first, the new tag went in the upper right corner. A couple years later they domed the tag so it would go over the embossed numbers of the previous year, and moved it to the lower right corner.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
During WW11 Wisconsin had a plate made from soybeans,if you got the vehicle around farm animals they would try to eat them.
interesting thanks for the replies
