2 members (dunfire, LAROKE),
69
Mod | | | Forums66 Topics128,194 Posts1,057,263 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | I recently picked up the rubber for the barn door seals on my '51 suburban. I guess I got tired of the metal bangin' on metal.
Was curious as to any tips or tricks of putting it on. I assume I need to use some kind of glue, and clean the paint and rust real good
Any advice?
Kurt | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | From your post seems like your on the right track. Assuming your not planning on painting your doors in the near future? Clean up the area for the weatherstrip, and I've always used 3M weatherstrip adhesive. I'd use the "clear" or "black" color cause the yellow really shows up. It will tack up and dry fast, leave your doors open overnite.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Kurt, patience is the word. Take your time and don't get in a hurry. A small section at a time worked for me. Good luck. | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Alvin,
Are you saying, put a little glue on, stick a few inches on put some more glue on and so forth?
I 'll look for the 3m glue.
Kurt | | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | Alvin,
Kurt That's what I did and it turned out good. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Kurt, yes, a little at a time. On a good run maybe 12" at one time but "check twice,glue once". It'll come out nice. I used the black on mine and cleaned any excess as I went. Take your time. The rear doors are a little tricky around the "latches/catches/guides". Good luck. Let us know how you make out with it. Be sure to take a couple snap shots. | | |
