| | | Forums66 Topics128,157 Posts1,056,875 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 22 'Bolter | | 'Bolter Joined: Oct 2003 Posts: 22 | Is it true that a gas tank from the 3100 will not fit the 6400 cab? I sure need a tank and the vendor I spoke with assured me the 1/2 ton tank will not work in my truck. Any ideas are welcomed. jc | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | your manual shows, all in cab tanks are the same size, is yours in the cab? Bill | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I installed a fuel tank from a 1951 Chevrolet 3100, in a 1952 Chevrolet 6400 several years ago, for my brother. Same identical tank. Vendors are usually the last people to ask Tech. questions. All they do is sell parts. | | | | | Joined: Oct 2003 Posts: 22 'Bolter | | 'Bolter Joined: Oct 2003 Posts: 22 | Well, I argued that the cab is identical. She insisted she had sold one for a 6400 previously and it did not fit. Easy enough, Spanky. I'll give it a go. Yes, Bill. It is in the cab. jc
| | | | | Joined: Nov 2011 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 52 | I just bought one from lmc for my 52 6400. Fits perfect.
52' Chevy 6400 2 ton
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I put an LMC pick-up tank in my 55.1 with out any trouble, Scott | | |
