7 members (Charles in CA, Otto Skorzeny, Lonnie, 1955 1 Series, dt235sd, Wickedbass, 1 invisible), 125 guests, and 2 robots.
Topics128,081
Posts1,056,076
Members48,434
#810100 12/24/2011 9:47 PM
Hi, I am new to the board and recently purchased a '37 Chevy 1/2 ton pickup. It is rough and in need of much work. It will need a grill for certain. Just curious as to who supplys decent repop parts for this model? Is Chevys of the 40's the only game in town? Has anyone used their grill with good results on fit and finish? Thanks, Dennis
kidagin #810125 12/24/2011 11:49 PM
Ex Hall Monitor
Ex Hall Monitor
"Good" as it relates to repop parts is sometimes not the right word to use. Many, if not most, are made in China and are frankly there only because no other options are available. There are a number of quality repop parts but don't be surprised if what arrives at your door needs some tweaking to make it work. Chevs of the 40s is one jobber. The Filling Station is another. Take the "links" link at the top of the page. You'll find a list with others. Are you planning to restore or rod it?
Tiny #810168 12/25/2011 3:11 AM
My plan for the truck is stock appearance with a slightly tweaked 235 and a 5sp. Daily driver reliable and safe. I would much rather use original grill and trim ect... but it seems '37 pieces are real hard to come by.
Unless your in a hurry, take your time, look around for parts at different vendors. Lots to consider. Also give the swap meet a chance. Never know what is out there at the time your looking.
On the other hand, I purchased a Stainless Steel grille for my 37 back about 1999 and its still in great shape. Got it from I&& Reproductions in Ca. Wasn't cheap then and certainly not now but has been worth the money in the long run....vs some chrome job that will crack or blister.
there is also jim carter, you can spend half your life on ebay, but sooner or later something shows up.
As you have figured by now, '37 was a one year only truck, some sheet metal is shared by the '38 and late low cab '36. Finding good used parts is pretty tough but not impossible. All the trucks from 1/2 ton to 5 ton will interchange piece except the front fenders, 1/2 and 3/4 ton only, 1 ton on up use bigger openings.
Joe
Joe H #810276 12/25/2011 6:06 PM
I am aware of many of the similarities and interchangability of parts between the pickups and larger models. I did buy a set of original fenders out of AZ for the pickup. I guess I'm just itching to start on the project. Trouble is, I haven't got it home yet. I will know better what I'm in for once I'm able to take stock of what I really need.
