| | | Forums66 Topics128,078 Posts1,056,021 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 5 New Guy | | New Guy Joined: Dec 2011 Posts: 5 | Hi, I am new to the board and recently purchased a '37 Chevy 1/2 ton pickup. It is rough and in need of much work. It will need a grill for certain. Just curious as to who supplys decent repop parts for this model? Is Chevys of the 40's the only game in town? Has anyone used their grill with good results on fit and finish? Thanks, Dennis | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | "Good" as it relates to repop parts is sometimes not the right word to use. Many, if not most, are made in China and are frankly there only because no other options are available. There are a number of quality repop parts but don't be surprised if what arrives at your door needs some tweaking to make it work. Chevs of the 40s is one jobber. The Filling Station is another. Take the "links" link at the top of the page. You'll find a list with others. Are you planning to restore or rod it?
| | | | | Joined: Dec 2011 Posts: 5 New Guy | | New Guy Joined: Dec 2011 Posts: 5 | My plan for the truck is stock appearance with a slightly tweaked 235 and a 5sp. Daily driver reliable and safe. I would much rather use original grill and trim ect... but it seems '37 pieces are real hard to come by.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Unless your in a hurry, take your time, look around for parts at different vendors. Lots to consider. Also give the swap meet a chance. Never know what is out there at the time your looking.
On the other hand, I purchased a Stainless Steel grille for my 37 back about 1999 and its still in great shape. Got it from I&& Reproductions in Ca. Wasn't cheap then and certainly not now but has been worth the money in the long run....vs some chrome job that will crack or blister.
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | there is also jim carter, you can spend half your life on ebay, but sooner or later something shows up.
| | | | | Joined: Feb 2000 Posts: 5,213 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,213 | As you have figured by now, '37 was a one year only truck, some sheet metal is shared by the '38 and late low cab '36. Finding good used parts is pretty tough but not impossible. All the trucks from 1/2 ton to 5 ton will interchange piece except the front fenders, 1/2 and 3/4 ton only, 1 ton on up use bigger openings.
Joe | | | | | Joined: Dec 2011 Posts: 5 New Guy | | New Guy Joined: Dec 2011 Posts: 5 | I am aware of many of the similarities and interchangability of parts between the pickups and larger models. I did buy a set of original fenders out of AZ for the pickup. I guess I'm just itching to start on the project. Trouble is, I haven't got it home yet. I will know better what I'm in for once I'm able to take stock of what I really need. | | |
