1 members (tesa), 142 guests, and 2 robots.
Topics128,080
Posts1,055,953
Members48,430
#80964 08/04/2007 12:01 AM
Junior Member
Junior Member
Removed an elecric fuel pump and replaced with the OEM mechanical one. Ran GREAT for about 20 miles. Ran better than ever. Then....started sputtering and stalling. Pulled choke out and limped it back to my shop. Runs poorly with choke engauges and wont even start with no choke. Any ideas? New fuel filter too.
James T
www.fixmyprinter.com
But honey...its for us!
#80965 08/04/2007 12:03 AM
A clogged fuel line somewhere is my first guess, check the little crooked spot at the top of the tank.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#80966 08/04/2007 12:09 AM
James,
I'll bet Brian is 'spot on' as they say across the pond! Maybe in your swap, some junk was introduced into the fuel lines/system...did you use any Teflon tape? My first check would be the needle and seat.
Stuart
#80967 08/04/2007 12:36 AM
Junior Member
Junior Member
I did use teflon tape. Should I have not?
James T
#80968 08/04/2007 12:42 AM
James,
Teflon tape does have its place, but most connections on the fuel system are mechanical..they are tapers against seats as opposed to tapered pipe threads. I save the Teflon for non-automotive uses and just use some type of thread sealant on the engine when needed.
Dig around, you might find some white stringy stuff plugging your carburetor....bingo! smile
Stuart
#80969 08/04/2007 12:50 AM
Junior Member
Junior Member
OK..I'll go diggin. THANKS!
James T
#80970 08/04/2007 1:41 AM
Fuel filters, before, after, and spares. If you can find an old glass bowl, they are neat to watch the junk build up in. My 2 cents.
Larry
I don't own a vehicle that isn't old enough to drink.
#80971 08/04/2007 2:51 AM
Does any one know where you can get the old glass bowls? I've been looking to add one to mine but can't find any.
1970 C50 dump! saving orphans from the CRUSHER
#80972 08/04/2007 3:39 AM
Rust Master, There are about 30 of on that auction site now. Some of them are the newer style, a lass cylinder with metal ends. The new style would serve the same purpose to view sediment build up. There is one from a 53 Chevy 2 door.
Larry
#80973 08/04/2007 3:46 AM
Most tractor supply stores carry sediment bowl type filters,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#80974 08/04/2007 3:50 PM
Hi JT66C10. If the above suggestions don't cure the problem, try swapping out the new fuel pump. I had the very same problem you are having after I put on a new fuel pump(mechanical). Except that I got about 30 miles down the road. It sorta sucks you can't trust new parts, but every once in a while they're bad right out of the box. Good luck.
1948 Chevy 6400
1964 Chevy 1/2 Ton
