10 members (DadsFirstPickup, TUTS 59, JW51, GRNHydra, Ponchogl, GradyB, Leo, Jon G, walterhvogel, 1 invisible),
50
0
Mod | | | Forums66 Topics128,080 Posts1,055,944 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#80964 08/04/2007 12:01 AM | Joined: Jul 2007 Posts: 31 Junior Member | | Junior Member Joined: Jul 2007 Posts: 31 | Removed an elecric fuel pump and replaced with the OEM mechanical one. Ran GREAT for about 20 miles. Ran better than ever. Then....started sputtering and stalling. Pulled choke out and limped it back to my shop. Runs poorly with choke engauges and wont even start with no choke. Any ideas? New fuel filter too. | | |
#80965 08/04/2007 12:03 AM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | A clogged fuel line somewhere is my first guess, check the little crooked spot at the top of the tank. | | |
#80966 08/04/2007 12:09 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | James,
I'll bet Brian is 'spot on' as they say across the pond! Maybe in your swap, some junk was introduced into the fuel lines/system...did you use any Teflon tape? My first check would be the needle and seat.
Stuart | | |
#80967 08/04/2007 12:36 AM | Joined: Jul 2007 Posts: 31 Junior Member | | Junior Member Joined: Jul 2007 Posts: 31 | I did use teflon tape. Should I have not? | | |
#80968 08/04/2007 12:42 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | James, Teflon tape does have its place, but most connections on the fuel system are mechanical..they are tapers against seats as opposed to tapered pipe threads. I save the Teflon for non-automotive uses and just use some type of thread sealant on the engine when needed. Dig around, you might find some white stringy stuff plugging your carburetor....bingo! Stuart | | |
#80969 08/04/2007 12:50 AM | Joined: Jul 2007 Posts: 31 Junior Member | | Junior Member Joined: Jul 2007 Posts: 31 | OK..I'll go diggin. THANKS! | | |
#80970 08/04/2007 1:41 AM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Fuel filters, before, after, and spares. If you can find an old glass bowl, they are neat to watch the junk build up in. My 2 cents.
Larry
I don't own a vehicle that isn't old enough to drink. | | |
#80971 08/04/2007 2:51 AM | Joined: Jan 2007 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 176 | Does any one know where you can get the old glass bowls? I've been looking to add one to mine but can't find any.
1970 C50 dump! saving orphans from the CRUSHER
#80972 08/04/2007 3:39 AM | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Rust Master, There are about 30 of on that auction site now. Some of them are the newer style, a lass cylinder with metal ends. The new style would serve the same purpose to view sediment build up. There is one from a 53 Chevy 2 door.
Larry
#80973 08/04/2007 3:46 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Most tractor supply stores carry sediment bowl type filters, Scott | | |
#80974 08/04/2007 3:50 PM | Joined: Dec 2006 Posts: 92 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 92 | Hi JT66C10. If the above suggestions don't cure the problem, try swapping out the new fuel pump. I had the very same problem you are having after I put on a new fuel pump(mechanical). Except that I got about 30 miles down the road. It sorta sucks you can't trust new parts, but every once in a while they're bad right out of the box. Good luck.
1948 Chevy 6400 1964 Chevy 1/2 Ton
