5 members (dt235sd, Hush, Rich'sToys, Toadwart, 1 invisible), 296 guests, and 3 robots.
Topics128,087
Posts1,055,999
Members48,430
#809229 12/22/2011 3:38 AM
I finally found a new electric 12v motor for my heater. The motor size is right, but the original has 3 tabs to mount it. Can I weld tabs on my new motor? Will the weld field ruin the magnets inside? I know to be very careful on heating, etc.
1947 First Series Chevy 2 ton COE
2005 - It started in the Gallery
2023 - Follow the restoration in my Project Journal
1962 IH Scout 80
1982 Chevy Caprice Classic
i'd use epoxy (assuming there is enough surface area for a good bond) and repaint. why risk it?
Stephen,
I don't know your welding skills or equipment set up enough to anwser "yes or no", so...
Have you got an old working motor to test your idea on? if not, do you have enough money to buy a new one?
If you answer "yes" to either one of these questions, then I think you are good to go.
Dale
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
-Unknown-
I can weld decently (not professionally). I have a MIG, so I was just thinking to drill small holes in the tabs (L-shaped) so I can just basically touch a spot weld through each hole. Maybe 3 holes per tab and wait between each to keep the heat down. The motors aren't too expensive, so I guess you're right, if I mess one up, I can buy another and try again.
1962 IH Scout 80
What you're saying sounds reasonable. I don't know how big the tabs are, but I would try to get by with the fewest number of plug welds as possible. I would start with just one. There can't be much stress placed on the bracket. Be sure to clean the spot on the motor casing down to bright metal before you weld.
Good luck.
-Unknown-
Keep your compressed air handy and as soon as you weld plug, hit it with cold air. Keeps the heat WAY down!
Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
