| | | Forums66 Topics128,020 Posts1,055,345 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Ok, this should be simple, I think. I find that if I press my brake pedal twice while stopping, the second time it doesn't go nearly as far down...almost like it needs two pumps to pressure up the lines. I'm not losing brake fluid anywhere, nothing is leaking. Is there maybe some air in the line or is this normal in old vehicles with no power brakes?
Truck's a 61 btw
Thanks for any insight! | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Maybe some air in the lines, maybe the brakes need adjustment, maybe both. Adjust the shoes up tight and back the off some. If that doesnt do it, get a helper and properly bleed them again. If it still feels off, adjust the pedal rod going into the master, Scott | | | | | Joined: Sep 2011 Posts: 1,451 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,451 | If I understand, the pedal is firm on the 1st apply but low, correct? If so then the brakes are out of adjustment. The springs haven't returned the shoes all the way when you jab them the 2nd (or 3rd) timecausing the pedal to rise.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jun 2009 Posts: 331 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 331 | Thanks guys. Yeah BC59 that is right, they are firm on the first apply but the pedal is low...they don't feel spongy at all. Guess I keep forgetting how old this truck is, the brakes don't adjust themselves, I have to do it, ha ha
