6 members (Peggy M, Rusted Nut, klhansen, 3B, tclederman, 1 invisible), 24 guests, and 10 robots.
Topics128,010
Posts1,055,308
Members48,419
#806959 12/15/2011 4:34 AM
Ok, this should be simple, I think. I find that if I press my brake pedal twice while stopping, the second time it doesn't go nearly as far down...almost like it needs two pumps to pressure up the lines. I'm not losing brake fluid anywhere, nothing is leaking. Is there maybe some air in the line or is this normal in old vehicles with no power brakes?
Truck's a 61 btw
Thanks for any insight!
Adam61 #806969 12/15/2011 5:04 AM
Maybe some air in the lines, maybe the brakes need adjustment, maybe both. Adjust the shoes up tight and back the off some. If that doesnt do it, get a helper and properly bleed them again. If it still feels off, adjust the pedal rod going into the master,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Adam61 #807010 12/15/2011 9:03 AM
If I understand, the pedal is firm on the 1st apply but low, correct? If so then the brakes are out of adjustment. The springs haven't returned the shoes all the way when you jab them the 2nd (or 3rd) timecausing the pedal to rise.
BC
1960 C60 pasture art
BC59 #807469 12/16/2011 8:54 PM
Thanks guys. Yeah BC59 that is right, they are firm on the first apply but the pedal is low...they don't feel spongy at all. Guess I keep forgetting how old this truck is, the brakes don't adjust themselves, I have to do it, ha ha
