| | | Forums66 Topics128,078 Posts1,056,021 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 61 Member | | Member Joined: Aug 2004 Posts: 61 | How easy is it going to be for me to swap out the 283 in my 64 Chevy Stepside for a 350? Also, any tips on a ground up restoration, which I am comletely new to, on this truck? :confused: | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | It should be a direct bolt-in, provided the 350 is of the pre-fuel injected era. As for the restoration tips, just clean, prep and paint everything properly and replace or rebuild anything worn or broken. Don't want to finish your truck and go back into it later to do a repair. Just my input, Scott | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Trading a 283 for a 350 is like trading Cheryl Tiegs for a Britney Spears poster: no class man, no class at all. Think very carefully before making that kind of move. Trading for a 327 would make since, but a dime a dozen universal motor like a 350 --- NEVER!!! Boo Radley  | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by Boo Radley: Trading a 283 for a 350 is like trading Cheryl Tiegs for a Britney Spears poster: no class man, no class at all. Think very carefully before making that kind of move. Trading for a 327 would make since, but a dime a dozen universal motor like a 350 --- NEVER!!! Boo Radley Cheryl Tiegs must be old enough to be Britney's grandmother... Cheryl would be past 55, and Britney must be about 20. Certaily possible from a biological standpoint. If 1964BowtieCrazyStepside is much younger than his truck he may not even know who Cheryl Tiegs is (was?). Real class in a '64 would be a 409. She's so fine my 409! 1964BowtieCrazyStepside: I have a running 350 I'd trade for a running 283.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Go with a 350. Parts are easier to find, cheaper and it will give you better performance. Don't listen to BR, I think he is actually a **** man. | | | | | Joined: Nov 2003 Posts: 41 Member | | Member Joined: Nov 2003 Posts: 41 | I think Britney Spears is pretty hot myself but i did pull a 283 out of my '63 and replaced it for a 350. :p I should at least get some cool points from you old guys for keeping the 3 on the tree. You cant tell me that shes not smokin' hot! [img]http://www-personal.engin.umich.edu/~dngo/musicians/britney%20spears.jpg[/img]
Joe K.
1963 Chevy Stepside 350 with 3 on the tree. 1960 Chevy Bel Air 35k original miles 1991 GMC Syclone #1557 1992 GMC Typhoon #0261
#8058 08/13/2004 11:13 AM | | Anonymous Unregistered | | Anonymous Unregistered | Cheryl Tiegs is 55, and she can drive my 409 anytime Boo Radley | | | | | Joined: Nov 2003 Posts: 41 Member | | Member Joined: Nov 2003 Posts: 41 | Cheryl Tiegs is a M.I.L.F. for sure. The only problem is that she is old enough to be my mom.lol So i guess what im saying is that Cheryl or a old 283 is ok but i would rather have Britney or a nice 300 hp 4 bolt main 350 anyday.
Joe K.
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Hey Syclone --- any cool points you might get for the column shift are sacrificed by the use of a 350. A hopped up inline, a 283, a 327, a 348 or 409, or even a 427 gets lots of cool points, but a run of the mill dime a dozen 350 costs ya cool points because, while it is true that they are very dependable and economical to work on, they are just way to COMMON to be cool.
Boo (Inlines Forever) Radley | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | There's no replacement for displacement, go with a 454 or a 502ci. They will be a direct bolt up but will require a bunch of small mod's to make it right. Scott | | | | | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | M.I.L.F....Now that's an acronym I never would have expected to see here! Yep, 350 would be a direct swap, mounts, brackets and all. IF you're doing a full-on restoration, keeping the 283 would be a smarter decision. I've actually thought it might be kind of neat to get ahold of an old 283 to play with. Wouldn't mind playing with Britney, either... Regards, Wannabe
"Don't expect anything and you'll never be disappointed"
