8 members (Gray_Ghost, Biermann, Hugh63c10, SmalltownTRKGuy, Phak1, Buckeye998, Gdads51, dt235sd), 138 guests, and 4 robots.
Topics128,165
Posts1,056,987
Members48,458
i'm changing my oil pressure gauge from 30 psi to 60 psi. in my 1953, once installed I proceeded to install the Oil Pressure Gauge Line, i bought the kit that comes with the the fittings as in this picture from this link:
http://www.classicparts.com/1947-77-...ctinfo/24-781/
however once installed it doesnt seem to tighted up the line I can basically pull it back out with little resistance. Am I missing something? does the line have to be flared or anything? Any help would be greatly appreciated.
thx.
Kent
1953 1/2 ton Chevrolet
1 Offline
Remove the fitting and see if it is crimped.. the line may have not been bottomed out when you tightened it therefore not crimping the fiiting on the line.. or the female fitting on your motor maybe different.. maybe someone had the same problem as you and will chime in.. but that would be my first two checks.
Daniel
1953 Chevrolet 3800 Stepside
thanks appreciate the help.
Kent
I had exactly the same experience. The page you listed doesn't show up for me but I used the same gauge so you are probably having the same problem. The fittings supplied with the kit look like standard compression fittings (especially if you wait until the gauge is installed and hard to visualize before checking everything like I did) but they are not. You need a tube nut. The same thing that secures your line down on the block. Unscrew the small fitting on the back of the gauge and the tube nut screws into that. DON'T OVER TIGHTEN the tube nut going into the gauge. The brass parts are just GLUED together. I learned this just prior to removing my instrument cluster for the 4th time.
The tube nuts can be tough to locate. I found one local auto parts store that had them after checking about 6 places. There is quite a bit of info on this you might find in a search.
Chuck
yep, someone here posted the actual part #'s not long ago. I believe they were for Napa....possibly even O'Rielly's.
EDIT: a search turned up this thread. Read it top to bottom and you will find the numbers listed.
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=755078&page=1
1951 3100 Chevrolet
Moderated by  ndkid275, Phak1
