5 members (arustycars639, DennisM, homer52, UtahYork, mick53), 100 guests, and 4 robots.
Topics128,268
Posts1,058,394
Members48,485
#804621 12/08/2011 1:58 AM
I am told that Jim Carter has the bushing kit that you need. You have the early style sway bar.
Greg_H #804671 12/08/2011 3:39 AM
Jim Carter sells two styles of bushing kits for 1947-55 Advance-Design Chevrolet sway bars.
1947 to early 1951
late 1951 to 1955
http://www.oldchevytrucks.com/cart/index.asp?sdes=sway%20bar%20bushing
The sway bar assembly at the links in the first post does not look like the later Advance-Design sway bar. However, I cannot see enough detail in the photos to be able to tell if Jim Carter's bushings for earlier A-D trucks might work in that sway bar.
Do you have a GMC or Chevrolet truck? The sway bars are different. I do not know if the GMC bushings are different from those used on Chevrolet truck sway bars.
It does not look like a 1954 Chevrolet panel body sway bar.
http://1954advance-design.com/Web%20images/SubSwayBar/index.html
when i got my 54 it was on there so im going to leave it
No problem. Just make sure you get the right rubber bushings.
Achipmunk #805009 12/09/2011 3:54 AM
Mine takes the 8 bushings 1951-1955.1 just like Tim's and Alvin's.
You need to figure out what type or model of sway bar you have.It might make finding the bushings easier .
Tim
1951 3100 Chevrolet
bowtietim #805021 12/09/2011 4:24 AM
I was told that either bar setup would work on a later truck but that the early style was designed to work on trucks that had lever style shocks. The early style mounts the bar to the front of the crossmember and the end links hook to plate where the front springs mount. The later style bar mounts to brackets that mount underneath the crossmember and the end links hook to brackets that clamp around the front axle.
Greg_H #805277 12/09/2011 11:05 PM
Curmudgeon
Curmudgeon
I don't mean to hijack this topic. Achipmunk and tclederman my 54 3100 sway bar looks like your pictures. I also am looking for replacement bushings especially the ones at the axle clamp. It's a bushing, with inner steel sleeve, that the pin goes through.
buoymaker #805297 12/10/2011 12:50 AM
Tim L posted the link above for the bushing kit.You will want Item # MEB349
$49.95 It comes with new pins as well.
sway bar bushing kit
Here is a picture of mine after rebuilding it.It's loosely fitted in the picture.
Front sway Bar
Tim
1951 3100 Chevrolet
