1 members (Hotrod Lincoln), 57 guests, and 1 robot.
Topics128,094
Posts1,056,066
Members48,433
#801352 11/27/2011 9:50 PM
I've just taken apart the side hood hinges on my 41, not the center. What do most people do with the rod in the hinge to keep it from rusting and bleeding all over the side of the hood? My first thought was to have it chrome plated. Any thoughts here.
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Galvanize them? I think chrome would be a bit excessive and a bit spendy.
They have sticks of material used to regalvanize areas where welds or cuts have been done on galvanized metal. That hinge pin is so small you may be able to get by without even having them galvanized. You need heat to apply the material, but I'm unsure as to of how much is actually needed.
Good question, I've never actually thought of this area before.
Jeff
My 1953 Chevrolet
1947.1 Gallery
homer52 #801748 11/29/2011 12:41 AM
If it's just a solid rod, I bet you could replace it with a piece of stainless. I don't know where you would go to find it, but I bet it could be found.
I looked into this during the restoration of my '41. Do a google search on stainless steel rod and you'll find suppliers with the appropriate size rod. Seems like it was 3/16 but can't remember for sure now.
My toys:
'41 Chevy Model AL 3/4 Ton
'40 Chevy Model KD 3/4 Ton
Hinomoto 209N Tractor/Backhoe
Norwood LM2000 Sawmill
PJ 16' Trailer
and a Brand New Shop!
Be what you is, not what you ain't, 'cause when you is what you ain't, then you ain't what you is.
Stainless sounds like the way to go.
1941 Chevy
I just put my hood back together today. I used stainless 3/16 rod. I bought it at a local hardware store. It was under $3 for a 3ft length. Looks like it is going to work fine.
Thirtyniner
39 chevy 1/2 ton
48 chevy fleetline aerosedan
Crusing in the Passing Lane
Don't forget, SS galls easily, so it would be a good idea to use plenty of anti-sieze. Most hardware stores have SS. My '37 GMC takes .25", am considering using nylon or teflon, very little shear here, main problem is rust that cannot be removed and properly protected except w/ bore cleaning brush.
Good idea on the bore cleaning brush, I don't think the stainless will gall because it's not stainless on stainless.
1941 Chevy
My '37 been together for 11 years since painting and has had a lot washes over that time. I have yet to see any sign of rust from the hood hinges. A small amount of oil goes a long way to keep them rust free.
Joe
Joe H #802598 12/01/2011 5:34 PM
I used stainless on mine - works great.
1940 Chevy KC 1/2-Ton
I put the old ones back in 3 years ago with a little WD40. No oil or ruct marks so far
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
