1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#803670 12/05/2011 4:47 AM
hi guy's can any one tell me if you can put a 47-53 grill on a 54 coe cab ? I found a 54 coe but I like the 47-53 grill better thanks Mike
rodtek1 #803683 12/05/2011 5:35 AM
The front fenders will have to be swapped too, there's a flat spot that coinsides with the grill that the earlier trucks don't have,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
48bigtrucks #803726 12/05/2011 1:06 PM
Mike,
If you find a set of earlier grill/fender/emblems (which are relatively rare, this being a COE), be sure to keep and sell your 54 COE parts (which are even rarer).
tclederman #803877 12/05/2011 11:59 PM
Wouldn't be a bolt up swap. Only way it would work, would be a complete front clip swap, but then the cowl is shapped different around the cowl vent, & would cause problems with hood closing.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
spanky #803894 12/06/2011 12:41 AM
well, it sounds like I would be better off to learn to like the 54 front clip more !! it's not that I don't like the 54. I had just pictured the 47-53 in in my mind when I started this build . thank you all for the info. Mike
rodtek1 #804222 12/06/2011 10:10 PM
I was the same way. I Preferred the look of the '47-'53 Chevy COE's more so, than the '54/'55 1st series Chevy, but as i set out to find one a '54 was also my first. I learned to like it. I later found what I was looking for, & some 30 COE's later, i've only owned three '54/'55 Chevy COE's. I later preferred the '47-'55 GMC COE's, over the Chevy COE's.
Spanky Hardy
1950 GMC 250 1-Ton
