1 members (ronsway),
185
Mod | | | Forums66 Topics128,167 Posts1,057,019 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | I guess this is sort of a poll.
I probably change the gear oil in the tranny and rear end every 5 years or so. What do you guys do?
Kurt | | | | | Joined: Sep 2010 Posts: 72 New Guy | | New Guy Joined: Sep 2010 Posts: 72 | You change your gear oil??  | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | I'm a total nerd. I do it spring and fall. I drive in alot of rain, oil is cheap by the pail, and when you have a pail, you can use a pail pump. It makes it no chore, and kind of fun to fill it back up. Before I had a pump, I used to heat the oil up for the suction gun, as I had no garage either. That stuff is thick when its freezing!
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Chris - how much rain do you get in the trans and differential??  I wouldn't be surprised if the oil in the trans and rear of my 58 was still the factory stuff  Bill | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I would change the gear oil as a new owner of a truck or while rebuilding it. Another reason is to inspect what comes out for any particles. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | Bill, you're right! I'm sure I change it too often, but if I don't, how can I justify the $43 I spent on the bucket pump? I'm just practising for my TT, I have get my strength up 'cause I'll be pumping 460wt oil in it. | | | | | Joined: Apr 2009 Posts: 252 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 252 | I only change it if I am in there for some reason, other than that I just check the level.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I think the guys pretty much touched all the bases Kurt. But what the heck, I'll throw in my two pennies worth just in case something was missed.
Change it if the truck is new to you as mentioned, just to see of there are any teeth in the bottom. Change it if you think it may have been in a flood or water over the running boards, they can pick up water thru the vent or bearings. Change it if you think it might not have the appropriate weight gear oil in them for the weather ahead an plan on driving a lot, as Chris mentioned.
The main reason for changing the oil in the engine is contamination from the combustion process. If the engine simply pumped air like a compressor then you would rarely need to change oil, simply keep it topped off. The trans and rear axle are not exposed to combustibles to contaminate them so they theoretically could go their entire life without being changed.
However, even the theoretical non-firing engine will wear. Pistons, piston rings, cylinder walls, bearings, cranks, cam & lifters all wear out. And with gear boxes and rear axles the gears, bearings, bushings, syncros, shifting forks all wear out eventually also. What wears off has to go somewhere so that alone would give reason to changing the fluids. And this is the prime reason that the factory recommends changing the gear oil at certain specified intervals.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Change if new to you and inspect gears and bearings. | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Wow,
Denny, Lots of opinions.
Main reason I change mine is to remove any water due to the possibility of condensation, and I figure the oil will break down eventually and loose its lubricating properties, and finally, if something is coming apart inside, I'd like to know about it, so I always take a look at the drainings and run a magnet through it.
Kurt | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Ken or Jerry should have more info on this but it’s my understanding that the biggest enemy to oil longevity next to contamination, is heat.
Consider that there is a light film of oil present on the cylinder walls and on the piston at all times. So every time the cylinder fires it burns off a tiny bit of oil the ash is eventually washed back into the main pool of oil. In petroleum oils with lower flash points the smaller molecules in the oil vaporize and burn off more rapidly than the larger ones. The larger oil molecules do not flow as easily and tend to coat the surface restricting the oil flow which would normally carry away some of the heat thus adding to the heat problem. I also recall hearing that the pour point depressant additives in multi-grade oils that keep the waxes from solidifying are used up quickly, which also contribute to oil thickening up. So does petroleum oil break down when subject to high heat in an infernal compression engine, sure does.
The synthetics stand up to high heat much better because they are compounded to have that same size molecule so even as some of the oil still burns away it remains consistent in its flow characteristics. Contamination heads up the list of reasons to change synthetic rather than compound breakdown and its not unusual to see recommended oil changes in the neighborhood of 10,000 miles using synthetic oils and a good filter.
And again, the transmission and rear axle is not subject to high heat like we see in the engine so there is very little break down in the oil over time. Denny Graham Sandwich, IL
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I thought of another reason to change it. This would be to stop worrying about it. I am not joking. Sometimes it is good just to have peace of mind about something like this. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | There must be water in gear oil. I have a TF centre section sitting in half a pail of gear oil and the part that is submerged has rust whereas the exposed does not. Weird or what? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Oil is lighter that water so it's possible that you some how got water in the bucket and any part of the centere section that's at the bottom could get rusty. How long has the bucket been sitting? Where in the barn did you have it sitting? Where did the oil come from, it fresh of drained?
DG
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | The owner's manual on my 09 F150 says that rear gear oil never needs replaced. Whereas on my 02 Dodge, I believe it stated 50,000 or so. Personally, I would only change it If I suspected a problem. I know there's trucks out there with hundreds of thousands of miles, that have never been changed. | | | | | Joined: Apr 2005 Posts: 17 New Guy | | New Guy Joined: Apr 2005 Posts: 17 | according to chevy... the new trucks are supposed to have all lubes changed ... i mean front and aback diffs, and transferr cases ... the new synthetic fluids do WEAR out..... good to use . overkill on older trucks ....my 2008 duramax just got changed... like 6 qts @ $14. ea... gm fluid is $35........progress???jm2cw..kev | | | | | Joined: Apr 2005 Posts: 17 New Guy | | New Guy Joined: Apr 2005 Posts: 17 | spoda change the brake fluid also....absorbs water... rusts the system......kev | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I take the approach that I don't know what is in there until I look. Someone mentioned that they change it if the vehicle is new to them. That is what I do so I know that the rear end most likely won't be a problem for me or the next person. I "assume" that the rear end grease has been in the rear end since it was new. So 50-60 year old used oil needs to be changed. I do it with out hesitation. I don't run synthetics in my old trucks either. I'm not saying synthetics are bad. Just saying I don't go through the expense of synthetics for my old trucks. | | |
