0 members (),
348
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 19 New Guy | | New Guy Joined: Feb 2008 Posts: 19 | What is the correct way to install the coil springs on the hood hinges to hold the hood up in the open position?? Thanks.
Nick Burton
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | What is the correct way to install the coil springs on the hood hinges to hold the hood up in the open position?? Thanks. I'm looking for the same info. I found this "how-to" but haven't found the tool.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I don't think that's for the coil springs on the AD links. Anyway, it doesn't specify what that tool will work on.
As far as I know the spring is not servicable separatly, at least I haven't been able to find the spring listed.
The new link assemblys are only about $35 and most of the vendors carry them.
I think most of the time the hood is simply maladjusted and it's not the spring that's at fault.
DG
Denny G Sandwich, IL
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Here's another hood spring tool. This one is for a mid-50's F-100. Similar hood spring to AD hoods. Click on "Instructions" to see how it works. I have no idea if it will work. I originally started the search for a hood spring tool for my buddy's '53 F-100 panel truck. He greased the spring after his restoration - now it won't stay up. I hoped that if he bought a tool, I could use it to remove my springs and blue them like D.G. told me a few months ago.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yep, and here are the original hinge links restored: http://www.pbase.com/dennygraham/image/140044212/large http://www.pbase.com/dennygraham/image/140044213/largeI hope you’re not thinking that the hood should pop up with those spring. The hood won’t stay up by itself until the links have reach their full movement and it the stops. Any thing lower that that and the hood will not stay open by itself. This is the stop on the link. It’s just like locking your knees when you have to stand in formation for a long time, cept you don’t have to worry bout the hood passing out, like you would: http://www.pbase.com/dennygraham/image/140044594/large And once again, I don't see what good it will do you to remove the spring unless you were able to find new ones, which probably isn't the problem in the first place. Denny Graham Sandwich, IL
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | For the "for what its worth dept.". I tend to agree with Denny. Most of you will remember what a time I had with getting my hood back on and adjusted correctly. I was ready to throw in the towel and buy new hinges and springs. Gosh, I was so aggravated with it. Then, I started all over and like Denny suggested, it wasn't the springs anyway. I finally got them and the hood shuts great. I just need to lift the rear of the fenders just a tat.
Good luck. You can do it. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Thanks, Denny and Alvin - I'll just clean up hinges and springs and try to convence myself that they look as good as Denny's. My buddy will be back in FL next week. We'll play with the hinges on his '53 F-100 (pic slow to load) to see why they are not holding the hood open. > NICK - Did Alvin and Denny answer your question? ... the spring does not hold up the hood by itself. Or were you asking how to install the complete hinge with spring? Sorry for leading your thread astray. I thought that you were asking how to install (remove) the spring from the hinge. - Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Feb 2008 Posts: 19 New Guy | | New Guy Joined: Feb 2008 Posts: 19 | I had took the coil spring from the hinges when I did the tear down. Cleaned and painted them. I know the spring are suppose to hold the hood up once opened.spring are find just checking on proper way to reinstall. 3 years since I took them apart. Thanks for your help!!!!
Nick Burton
Nick Burton
| | | | | Joined: Feb 2008 Posts: 19 New Guy | | New Guy Joined: Feb 2008 Posts: 19 | Thanks for believing I can do it????????
Nick Burton
| | | | | Joined: Feb 2008 Posts: 19 New Guy | | New Guy Joined: Feb 2008 Posts: 19 | I think I finally figured out the how to....thanks to everyone's help.
Nick Burton
Nick Burton
