2 members (NJC, baldeagle), 52 guests, and 5 robots.
Topics128,014
Posts1,055,327
Members48,419
#800848 11/25/2011 10:52 PM
O.K . the most of you know i'm yanking out the old 235 in place for a sbc 305 , so fsr so good , hey what would be a good header sugestion , I'm building on a budjet so i don't care if there chrome or ceramic , or even used , whats some good suggestions ( and as you remember there going in 2nd series 55 pickup thanks in advance for any good advice !
55redstove #800853 11/25/2011 11:25 PM
I don't know if they would have the firewall clearance you need but I would want to take a look at the log style manifolds originally used on 55-56 autos. I suspect something like that was used in the original V8 powered 55/2 pickups.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
55redstove #801096 11/26/2011 8:57 PM
in.teresting development , nearing compleating on 305 rebuild , when discovered a starteling discovery , no compression on any cylinders , WTF ? this is way to far along to just now discover this ! any ideas or suggestions , 55 redstove PLEASE HELP
55redstove #801118 11/26/2011 10:06 PM
ramshorn manifolds are what was original for the TF V8 and work as well as any headers ..... maybe you have a bunch of valves adjusted too tight and not closing?
squeeze #801787 11/29/2011 2:58 AM
i'll go through and readjust all of them again tomorrow , to see what happens ,! Thanks
55redstove #802317 11/30/2011 10:03 PM
no difference , you know its almost like if I leave the rocker nuts very loose i start to develop compression , but if i go by the book 1/2 turn tighter after snug , no compression whatsoever on any cylinder , what could cause this , do I need shorter pushrods or perhaps the piston rings are at suspect , HELP?
55redstove #802357 12/01/2011 12:27 AM
Riding in the Passing Lane
If you are using the old lifters they are probably sticking in the top position. Adjust the valves so you just take up the slack & leave about 2-5 thousands clearance. Go ahead & start it up when you are ready. After it warms up a bit start adjusting them down one at a time with the engine running. At first it will miss & then settle down. If so go ahead & adjust it down about a quarter turn. If they wont settle down go ahead and adjust them to 5 thousands. It will run OK that way but make a little noise. You might try again after you run it awhile. If you want to be perfect you will need to replace the cam & lifters.
If you already put in new lifters then you are adjusting them from the bottom of the travel.
1972 Chevy c10 Cheyenne Super
new cam and bearinge , a nd new hydralik lifters, installed as well as new pisrton rings , and double roller timing gear set ,!the only thing i didn't do and wish i would of was valve job but my machinist saad it wasnt absoluyely necessary !
55redstove #802444 12/01/2011 3:55 AM
Sounds like the cam is out of time with the crank, maybe,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
set to exacting specks, ! i even tried 180 no difference put it back to book specks
