| | | Forums66 Topics128,198 Posts1,057,269 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 23 New Guy | | New Guy Joined: Apr 2011 Posts: 23 | I am replacing all the glass in my 51 5 window. there all in except the door and vent windows. I spent all day today trying to figure out how they go in, I know I,m doing some minor thing wrong, I have read and re read the shop manual http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0101.htm and it seams pretty straight forward. Everything seems to fit well till I try to install the vent window assembly.I was hoping someone will have some tips for me. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ... The FIRST time I put mine in it was a little tough. After pulling it back out a couple times for unrelated reasons, I got to where I could drop it in pretty good. Patience is the best advice. I will admit I read the "instructions" about 4 times just to get it in my head clear. Do you have a specific point at which you have the problem. That may help us to help you..... once its sitting down in the door its a little bit of a pain to get up inside the door to put the bolt in the leg of the assembly.
| | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | Re-installing the vent window assembly always seems to be the trickiest bit! When I was replacing my cracked door windows and reassembling everything, the vent window assembly always seemed to catch on the drip rail before sliding in. Just be patient and work it in.
Dave Baird 1951 Chevy 3803Foot starters are for Stovebolters and people who need a kick in the ...
| | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Mask the window opening so you don't scratch the finish.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Apr 2011 Posts: 23 New Guy | | New Guy Joined: Apr 2011 Posts: 23 | Thanks everyone for all your help and suggestions. I still cant get the vent windows in, I can usually figure just about anything out but this has be baffled. either the lower part of the vent window hits the spring on the window regulator or the upper part of the vent window hits the window channel and wont slide down the window glass straight. John | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | John -
I did the vent assemblies on my '54 3100 recently. One of the assemblies almost fell into place. The other was a bear. The door that was difficult had been wrecked and repaired somewhere along the way. Possibly, the opening between the outer skin and the inner skin of the door was a little smaller (?).
You seem to be saying that you are trying to slide the vertical bar down against the window glass. That won't work. You must insert the assembly at an angle tilted toward the latch side of the door with only a corner of the window glass in the vertical track. Then rotate it into place, overlapping more of the window glass as you get the assembly into place. The window glass is pretty tough, but you could crack it if you manhandle it too hard.
Admission of guilt: I installed the assembly into the "troublesome" door, but I don't know what I did. It just finally went it. Maybe I was holding my tongue a little differently!
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Apr 2011 Posts: 23 New Guy | | New Guy Joined: Apr 2011 Posts: 23 | Lonnie Thanks !! that was my mistake, I was trying to slide the vent channel down the glass. My windows are in.... I cant thank you and the rest that replied enough. John | | | | | Joined: Sep 2010 Posts: 72 New Guy | | New Guy Joined: Sep 2010 Posts: 72 | | | |
