7 members (Bill Hanlon, Sjm, Gdads51, crenwelge, 51sub, Pre '68 Dave, Shaffer's1950), 128 guests, and 3 robots.
Topics128,260
Posts1,058,313
Members48,485
#799716 11/21/2011 4:20 PM
I need to take out the rear fender braces on my 49 chevy truck to add clearance. Has anybody done this with any success?
Chuck49 #800093 11/22/2011 11:10 PM
If you mean the 'C' section braces up in the top centre of the rear fenders,a lot of guys with radically lowered trucks seem to do this often,and I haven't heard of any real problems.
AFAIK it's an easy thing to do,leaving just two small holes to fill.
Chevrolet obviously considered them necessary but I assume your truck will not be used in a commercial sense,i.e lugging heavy loads around any more....
I imagine you'll be OK.
More pix on Flickr.
Thanks for getting back to me. I guess I was afraid the fender would wobble. What is AFAIK?
Are you really in Scotland? If so 1.what kind of beer do you drink? 2. Anything good to eat? 3. Whats the wheather like? My family is originally from Scotland my last name is Bruce. I can't believe I'm writing to somebody in Scotland!
AFAIK...."as far as I know"
You can do away with the brace that's inside the center of the rear fenders for added tire clearance. But do not eliminate the rear brace that goes from the rear bottom edge for the fender up the the frame. Your fender will flap around if you don't use the rear brace.
Thanks Alvin!
Chuck,to avoid the wrath of the Moderators,we should stick to 'on topic' matters in the sub-forums.(Just keepin' you right)
The fenders are fairly stout pressings due to their compound shape,but as wbrowne correctly points out,the rod braces at the rear of the fenders must be fitted.
You'd be amazed at just how much of a difference they make.
I might have to trim my centre ones slightly as my tyres may rub on full compression of the suspension,but I won't have to remove them altogether.
More pix on Flickr.
I took out the fender braces. Tightened all the bolts up on the fender to the sides and the running boards. I can't even tell I took out the braces. The fenders are firm with know movement.
Thanks for your advice.
