2 members (NJC, greenie-reddy),
159
Mod | | | Forums66 Topics128,260 Posts1,058,287 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 67 | I need to take out the rear fender braces on my 49 chevy truck to add clearance. Has anybody done this with any success?
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | If you mean the 'C' section braces up in the top centre of the rear fenders,a lot of guys with radically lowered trucks seem to do this often,and I haven't heard of any real problems. AFAIK it's an easy thing to do,leaving just two small holes to fill.
Chevrolet obviously considered them necessary but I assume your truck will not be used in a commercial sense,i.e lugging heavy loads around any more.... I imagine you'll be OK. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Dec 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 67 | Thanks for getting back to me. I guess I was afraid the fender would wobble. What is AFAIK? Are you really in Scotland? If so 1.what kind of beer do you drink? 2. Anything good to eat? 3. Whats the wheather like? My family is originally from Scotland my last name is Bruce. I can't believe I'm writing to somebody in Scotland! | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | AFAIK...."as far as I know" | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | You can do away with the brace that's inside the center of the rear fenders for added tire clearance. But do not eliminate the rear brace that goes from the rear bottom edge for the fender up the the frame. Your fender will flap around if you don't use the rear brace. | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Thanks Alvin! Chuck,to avoid the wrath of the Moderators,we should stick to 'on topic' matters in the sub-forums.(Just keepin' you right)
The fenders are fairly stout pressings due to their compound shape,but as wbrowne correctly points out,the rod braces at the rear of the fenders must be fitted. You'd be amazed at just how much of a difference they make.
I might have to trim my centre ones slightly as my tyres may rub on full compression of the suspension,but I won't have to remove them altogether.
| | | | | Joined: Dec 2008 Posts: 67 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 67 | I took out the fender braces. Tightened all the bolts up on the fender to the sides and the running boards. I can't even tell I took out the braces. The fenders are firm with know movement. Thanks for your advice. | | |
