4 members (Scott, Joe H, 3B, 46 Texaco), 75 guests, and 5 robots.
Topics128,185
Posts1,057,275
Members48,467
Page 52 of 177 1 2 … 50 51 52 53 54 … 176 177
Still chippin' away at the old worn out 2 tone paint job. Today I sanded and de-glossed the rear fenders and roll pan. Mocked up the right rear fender to get an idea of how the two tone paint job will look.
http://inlinethumb17.webshots.com/46928/2889649980103882008S600x600Q85.jpg
http://inlinethumb59.webshots.com/49658/2329701390103882008S600x600Q85.jpg
http://inlinethumb57.webshots.com/46648/2035969370103882008S600x600Q85.jpg
@ the green farmer, we are restoring to original condition. We are going to add radial tires and one piece rim.
I've been busy this evening trying to prepare for the "great drilling". That is the drilling of the holes in my dash to contain my turn siginal leds. It's a scary thing to do, drilling holes in the dash. I got some sage advice from John the Jockbolter and put it to work. Below are some pictures of how I managed to pinpoint where to drill. My plan is for one led (high beam) centered and two leds above spread out a bit.
Prepare for leds
Measure for vertical
Marking for vertical
Vertical
[/url] for horizonal
[url=http:...0/?action=view&current=Done.jpg]Done
~Jim
Glad you got things marked out Jim,the next step is the biggy.....don't slip!!! lol...
More pix on Flickr.
Yeah, you're full of laughs ole buddy. I will be buying new bits for this operation.
~Jim
Removed the drivers door and put in new bushings and pins into the hinges. I cant beleive they used plastic as a bushing. The new Bushings are way better.
http://talk.classicparts.com/picture.php?albumid=180&pictureid=1764
HOT ROD JOHN, Sure wish I could find a nice set of fenders like that for my pickup. Looking good.
1959 Chevy Apache 3100/ 283 TBI / 4L60E
My YouTube:
https://www.youtube.com/mikebtte
I installed Driver side window and two new door handles!!!
My latest coup. My son wanted to fabricate a shelf to cover the area where the gas tank was. We cut it out of stainless and will use the area for storage.
Making a Template
Template
Ready to Cut
Cutting the Shelf
Finished
~Jim
Been working on removing the dents from the rear fenders for the last week. Next time I'll just buy new ones!
Robert C.
I'm a Genius in the making.
1950 3600
Socket Breaker
Socket Breaker
had a flat left rear tire... off and on, plugged and done.
fun.
-W
Got the 216 and straight axle removed, frame prepped for Fatmans IFS and 283 engine
Removed seat and gas tank,twisted off 3 bolts, found some 50 year old dirt under gas tank. Blaster probalbly saved a couple of other bolts. Tomorrow remove twisted off bolts and clean out cab, you gotta love working on these old gems.
1955 Second Series GMC
"Done - A 50 Year Journey"
Follow in the DITY
-- No one said it was going to be easy
Bolt broke on a stablisher bar on the bottom control arm on the 37 pickup. What a pain to drill out....had to tap it deeper and will get a longer bolt. Got that done and called it a night. Need to get a bushing and longer bolt,grade 8 or course, and I'll be "on the road again".
I ran my accessory wire for my under the seat plugs.
~Jim
Holy Cow! that hammer tone looks Ninja on that Heater!
New pics of the zombus. she was painted gold and forest green in side . yuck. We found a gallon of magenta floor paint with non stick in it at home depot for 6 bucks, and took to it with mini rollers. Scraped all the black fuzzy crap off the celling ,primer and and rattled it key lime. made door panels out of the paneling I found on a busted entertainment center. I will wrap them in leopard fabric eventually but rolled some of the magenta floor paint on em for now.
http://a8.sphotos.ak.fbcdn.net/hphotos-a...527004123_n.jpg
http://a6.sphotos.ak.fbcdn.net/hphotos-a...366109083_n.jpg
http://a3.sphotos.ak.fbcdn.net/hphotos-a...029074585_n.jpg
http://a1.sphotos.ak.fbcdn.net/hphotos-a...855700605_n.jpg
http://a3.sphotos.ak.fbcdn.net/hphotos-a...940925000_n.jpg
http://a3.sphotos.ak.fbcdn.net/hphotos-a...947802017_n.jpg
Found a flat left rear tire. Need to see if stem or bad bead - slow leak. Been shopping for wood for my bed and today I bought CYPRESS boards.
Oak is to spendy for me right now and the yellow pine I am concerned about warping. Have local sawmill that sells log homes http://www.thriftloghomes.com/
Went out and talked with owner today. Got all the 2 yr. air dryed lumber I needed then asked to have it planed to 3/4" thick. $75 out the door for those that want to DIY. Your mileage may vary but for me I have more time than $$ so this will work out good. Will stain with darker log home stain to bring out grain, highlight the honey hues and protect it from moisture.
Here are pics of the lumber:
http://s5.photobucket.com/albums/y175/ShepFL/Vintage%2049/
Be the person you would want as a friend because at the end of the game the King and Pawn go in the same box.
Good looking wood! What will you do for bed strips?
~Jim
Dropped the doors today on the 65. Now onto removing the interior.
Marked and drilled the hole for my turn indicator. Decided to install only one turn light on the dash. With that and the high beam indicator on the dash I have finished all work under the dash. Getting close to the finish line.
The turtle...
~Jim
AS usual i just drove it. i filled the gas tank and checked the mileage. in mixed in town and out of town driving, i drove 40 miles on the two lane highway round trip and i got 17.5 for the week. the irony is that i got the same mileage on the truck as my 2003 PT cruiser turbo driving the same mixed mileage.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Undecided at this point. Most of the trucks I see at the cruise ins are Stainless. Thinking of going with steel painted same as truck. Not sure of color scheme tho as it is early in the game.
What do you like to see? I plan on keeping this rig stock with basic safety upgrades.
pulled a 50' x 30' tarp over the truck, getting ready for the snow!
fixed a surprise gas line leak
Rick
58 3600 4 on the floor
I replaced the gas tank sending unit. The gauge now works fine. Looking at the design on the orginal, I'm suprised it lasted as long as it did.
Also replaced the gas cap (old one was leaking after a fill.
No major projects until spring. Just driving it when I can.
Have a safe holiday.
work in progress.
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
David,
That looks like a great truck. Keep us updated on how it goes. Plenty of pics of your work.
~Jim
I reinstalled the fenders and steps on my '65 short bed. I used Peel & Seal ofor fender welting, worked great and was one of the easier projects I have done thus far on my truck. Here is a how to link, see post #105:
http://talk.classicparts.com/showthread.php?p=78694#post78694
I have two power outlets down on the front of the seat. I had wired them under the seat and today put the seat in and tried to run the lead to the fuse box. A bang and a flash told me something was not well under here. It seems I have a pesky ground somewhere. My son will be coming over soon to help me pull the seat out so I can check it out.
~Jim
Installed fog lights with a remote sensor so they can be independently opperated without adding another switch in the cab. And an oil change after the holliday stop and go driving. Got the remote controller from pep boys for about 30 smackers and was supper simple to install. Has a built in relay, and has a good range On the remote (About 80 feet id say). If any of you want more info on it let me know!
66' Chevy C-30 Rat
Brian,
Do you have a product number on that?
~Jim
back yard wrench turner
Put some interior panels into electrolysis for rust removal and took off the overload springs and stops on the rear.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Cut and installed my choke cable and fitted heat shields to the exhausts where they pass close to the starter and brake M/C.
I also made a panel to hold the airspring temporary inflation valves until I get a proper control system.(More $$$!)
More pix on Flickr.
Cleaned and painted 2 rims to have tubes and tires mounted on. Got all the bolt holes cleaned out and bought new grade 8 bolts with lock washers to mount my recently acquired. 3 speed transmission. Cleaned up and spray painted my e brake handle and reassembled it.
Brian,
The pn on the package is PL-HARN7A. Its a pilot brand, there is probably info on it on the pilot website (Pilotautomotive.Com)
66' Chevy C-30 Rat
Thanks Buddy
~Jim
My son visited from Chicago for the Holiday and with his assistance I FINALLY got that 1946 windshield out!
The internal rust within the hinge assembly prevented it
from opening enough to get a screwdriver on the upper screws to the window frame. I finally had to break down and cut the heads off. Next challenge: removing the studs from the frames without hurting anything.
Milk the cows you have
This weekend I got the 3" dropped I beam from Sid's installed. New king pins went in smooth as butter. Got the tire rod & ends from Classic parts & they are great.
Today I ordered misc parts - axle dust caps, shock mounts & shocks etc.
Can't wait to get it back to gether & go crusin.
1949 chev 3100 3 window. 350hp/327/m21 4 spd, 12 bolt rear, power brakes, 3" dropped axle from Sid's. Disc brakes next.
Good looking 56 there and helpers.
~Jim
http://s783.photobucket.com/albums/...tion=view&current=taillights1128.jpg
I added new LED tail lights. Still waiting on the bumper brackets to arrive…….
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
