1 members (Hotrod Lincoln), 130 guests, and 2 robots.
Topics128,143
Posts1,056,494
Members48,442
#7989 09/07/2004 12:12 AM
Junior Member
Junior Member
does any one know what kind of axle could be under this truck? I can tell you that it is a perfect circle shaped cover and that from the books i have, NOT a dana axle. can't find the i.d. tag either. the problem is that theses books dont tell what it IS. Also, did th400's come stock in these fine automobiles?
#7990 09/07/2004 12:13 AM
Junior Member
Junior Member
ooops. It is actually a 3/4 ton.
#7991 09/07/2004 1:27 AM
If it has a removable differential carrier and a removable rear inspection cover, I would say you have an Eaton differential. I have a couple and they are indestructable.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#7992 09/07/2004 2:32 AM
H Online: Content
The Eaton was pretty much the standard 3/4 ton and 1-ton rear end, and was used for several years. It had several ratio options, and was even available with a Detroit Locker differential in the later models. We ran them in dirt-track race cars in the 70's, behind 500-HP engines without any real problems. They were goshawful heavy in those dirt cars, though! One identifying feature is a backlash adjustmnet on the side of the carrier housing on the driver's side, that bears against the side of the ring gear when it's coasting. Tricky to adjust!
#7993 09/07/2004 6:39 PM
Junior Member
Junior Member
It does kinda have that heavy duty indestructable look to it. Thanks for the info guys.
#7994 09/07/2004 9:17 PM
You probably have the TH400 tranny, the way to identify it is by the shape of the pan. Go here:
http://www.novak-adapt.com/knowledge/th400.htm
Your differential should be either a 10 or 12 bolt, you count the number of bolts in the cover. From my knowledge of these you should have a 4.10 gear ratio, since you have the automatic. Standard tranny was the SM465, which came with 4.57 gears.
Fred
52 3600
69 C-10
#7995 09/08/2004 12:56 AM
Z
Z Offline
i had a 69 3/4 longhorn.its auto trans had an extra low first gear.it would whine through first.
