| | | Forums66 Topics128,164 Posts1,056,977 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2000 Posts: 199 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 199 | Has anyone run modern truck rims on their 1 ton? My son found a set of late model HD rims. Polished aluminum. Complete with caps tires and all. Offset is too deep for my truck and the 16" rubs on the steering arm end. I'm not looking to make it a full stocker so I'm not ready to shell out $800 or more for tires and tubes and possibly replace one of the stock 17" rims.
The truck will be more for cruising around and probably not see a full load other than maybe picking up a small block once in a great while.
Are there other options?
Thanks! | | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | We ran into a similar problem when we put new Dodge rims on my Dad's '49 3/4 ton. We went to the junk yard and picked up a set of Dually truck front hubs (AD body style). Take off the original hubs and put on the dually hubs and you're good to go. They even use the same bearings.
That led to another problem though. . .the offset was wrong for the rear-end now! We opted to get a new rearend out of a Dodge van that was wider than the stock axle. That spaced the rear wheels out to match the fronts.
One other problem, but not a huge one is that this will increase the "scrub" of the tires because the centerline of the tire is now outboard of the kingpin. Like I said, not a big deal if you're just using the truck for cruising.
Good luck!
Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
| | | | | Joined: Apr 2000 Posts: 199 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 199 | How far out do the dually front hubs move things? I don't have any of those around to compare other than my 1 1/2 ton! Did they use the same brakes up front as well?
I'm going to have to get something to move the rear's out a little anyway due to the minimal clearance to the backing plate. | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | I run modern (read: new) rims and tires on mine, but I shelled out $1200. That's with singles. Probably not what you wanted to hear.
Dave Baird 1951 Chevy 3803Foot starters are for Stovebolters and people who need a kick in the ...
| | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | I'll have to measure Dad's unless someone else chimes in with the info. I don't recall changing anything with the brakes though, so they must be the same.
As far as the rear axle, I picked up a dually conversion kit (made for single wheel trucks) and used the spacer from that kit on my '50 to get my wheels out where I wanted them. They are a bolt on spacer that is about 6". You can find something similar in JC Whitney.
Craig
CK
| | | | | Joined: Apr 2000 Posts: 199 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 199 | I don't want a dual rear end. I want my 1 ton to look like a pickup. It has a bed with fenders. 9 1/2 feet of bed!
I have a 1 1/2 ton with duals already. I also have a dually 1 ton 1992 truck.
I just want the front to clear the steering with the modern HD 16" polished aluminum rims.
It may not be meant to be. The guy I'd been referred to with the website for the "immediate" quote hasn't answered in 4 days.
| | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | The Dually spacer for the rear end isn't to make it a dually in your case. It would space the newer wheels you are wanting to use out so they fit right. They have such a shallow backspacing that they would be too far inboard to look right without either a wider axle or the spacers.
I'm heading out for Thanksgiving, but I'll take some pictures when I get back and post them. After all, a picture is worth a thousand words!
Craig
CK
| | | | | Joined: Apr 2000 Posts: 199 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 199 | Thanks, Craig. Those are what I'm looking for. It looks like the spacer might be the same or if I got 2 of the front ones, I'd be set.
My 1 ton rear is already wider than the front but it will depend on what these hubs do. I do think the rears need a small spacers and I'll look to change to the larger studs.
Now to FIND them!
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 |
| | | | | Joined: Apr 2000 Posts: 199 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 199 | Are those 4" deep?
I'm going to buy aluminum spacers and change the studs to the larger diameter that belongs on these rims.
I'm using GMT400 dually front spacers on the rear to give me a bit of room between the wheels and the brake backing plate. I'm knocking the locator pegs off of those to start the new year! | | |
