| | | Forums66 Topics128,288 Posts1,058,574 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 8 New Guy | | New Guy Joined: Oct 2011 Posts: 8 | I have a 52 with a 216. The oil filter canister is cast and bolts to the side of the block and has no lines running to it I've seen some that are stamped metal and bolt to the side of intake with lines running to it. I can't figure out what oil filter to get. I picked up a Fram C4P which is for bypass oiling. It didn't fit, too large in diameter, bottoms out on the taper at the bottom of the canister. There is a Fram C4 but RockAuto says it's for full flow, I only thought these were bypass flow? Here's a pic of the canister. You will note there is tube in the bottom of the canister. This tube sticks up a little and seems to interfere with the filter thats currently in it. Does anyone know what filter is the correct one. Any input would be much appreciated, thanks in advance! [IMG] http://i595.photobucket.com/albums/tt35/rjamsehuss/IMG_1269.jpg[/IMG] [IMG] http://i595.photobucket.com/albums/tt35/rjamsehuss/IMG_1266.jpg[/IMG]
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | A topic about these filters was just discussed recently. Try searching for Inner-Line oil filter and see what comes up.
Jeff | | | | | Joined: Jun 2008 Posts: 1,388 Shop Shark | | Shop Shark Joined: Jun 2008 Posts: 1,388 | It looks pretty clean, why not just unbolt it, clean it up real nice, and take it to the flaps. Then you can shove different filters in there.
Or, you could measure it, and measure the filters. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Here is the LINK to the recent post. Lots of good info.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | The WIX 51010 filter with a WIX 51017 cover gasket is what I use on my Inner Line filter. Haven't had any problems. Cover gasket included with filter is too small.
Ed
| | | | | Joined: Oct 2011 Posts: 8 New Guy | | New Guy Joined: Oct 2011 Posts: 8 | Thanks for all replies. I cross referanced the 51010 to a Fram and which is a C3, the dimentions on this look right. I had a WIX 51006 which didn't fit. I was originally looking at a Fram C4 or C4P, and according to thier website they have different dimentions. At O'Reilly's they cross referanced a Wix and both the C4 and C4P cross to a Wix 51006, somthing wrong here. I've alawys like O'Reilly's but they disappointed me on this one a little. I'll have to see if I can a 51010 tomorrow. I think my old gasket is in good enough shape to reuse.
Thanks again! | | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | If this is an inliner filter, that small tube is probably the supply or inlet. Make sure the filter does not block the tube. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Ive never seen a 216 engine with side motor mounts,I'm not sure what you got.
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1952 pass was the first year for side mounts and the last year for the 216 in cars.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2011 Posts: 8 New Guy | | New Guy Joined: Oct 2011 Posts: 8 | 51010 worked. Gasket from a 51006 will fit also. Cut the top of my box and threw it in the glove box. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I have a standard NAPA Gold filter in my Inner Line housing. Not sure which WIX is its match offhand tho. If this is an inliner filter, that small tube is probably the supply or inlet. Make sure the filter does not block the tube. It is and there should be a heavy spring at the bottom to press the filter against the lid. Nice find! | | |
