Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (Rosco, 49nut, Ghost_Rider, TUTS 59, tclederman), 126 guests, and 1 robot.
Topics128,280
Posts1,058,590
Members48,492
#798874 11/18/2011 4:55 AM
I have a 52 with a 216. The oil filter canister is cast and bolts to the side of the block and has no lines running to it I've seen some that are stamped metal and bolt to the side of intake with lines running to it. I can't figure out what oil filter to get. I picked up a Fram C4P which is for bypass oiling. It didn't fit, too large in diameter, bottoms out on the taper at the bottom of the canister. There is a Fram C4 but RockAuto says it's for full flow, I only thought these were bypass flow?
Here's a pic of the canister. You will note there is tube in the bottom of the canister. This tube sticks up a little and seems to interfere with the filter thats currently in it. Does anyone know what filter is the correct one. Any input would be much appreciated, thanks in advance!
[IMG]http://i595.photobucket.com/albums/tt35/rjamsehuss/IMG_1269.jpg[/IMG]
[IMG]http://i595.photobucket.com/albums/tt35/rjamsehuss/IMG_1266.jpg[/IMG]
hussey #798892 11/18/2011 5:45 AM
A topic about these filters was just discussed recently. Try searching for Inner-Line oil filter and see what comes up.
Jeff
My 1953 Chevrolet
1947.1 Gallery
It looks pretty clean, why not just unbolt it, clean it up real nice, and take it to the flaps. Then you can shove different filters in there.
Or, you could measure it, and measure the filters.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
Mr. Lang #798919 11/18/2011 8:54 AM
Try Wix 51010
DADS50 #798970 11/18/2011 4:51 PM
Here is the LINK to the recent post. Lots of good info.
My Blog
The WIX 51010 filter with a WIX 51017 cover gasket is what I use on my Inner Line filter. Haven't had any problems. Cover gasket included with filter is too small.
Ed
Forty9 #799092 11/19/2011 2:40 AM
Thanks for all replies. I cross referanced the 51010 to a Fram and which is a C3, the dimentions on this look right. I had a WIX 51006 which didn't fit. I was originally looking at a Fram C4 or C4P, and according to thier website they have different dimentions. At O'Reilly's they cross referanced a Wix and both the C4 and C4P cross to a Wix 51006, somthing wrong here. I've alawys like O'Reilly's but they disappointed me on this one a little. I'll have to see if I can a 51010 tomorrow. I think my old gasket is in good enough shape to reuse.
Thanks again!
hussey #799102 11/19/2011 3:25 AM
If this is an inliner filter, that small tube is probably the supply or inlet. Make sure the filter does not block the tube.
1951 1 Ton Completed
Ive never seen a 216 engine with side motor mounts,I'm not sure what you got.
Tim
1951 3100 Chevrolet
1952 pass was the first year for side mounts and the last year for the 216 in cars.
My Blog
Forty9 #799784 11/21/2011 9:10 PM
51010 worked. Gasket from a 51006 will fit also. Cut the top of my box and threw it in the glove box.
hussey #799786 11/21/2011 9:16 PM
A guy on the HAMB posted this for me. Pretty cool to have. It shows the PN. Fram C3 which crosses to a Wix 51010.
[IMG]http://i595.photobucket.com/albums/tt35/rjamsehuss/InnerLineOilFilter.jpg[/IMG]
truckernix #799795 11/21/2011 10:21 PM
I have a standard NAPA Gold filter in my Inner Line housing. Not sure which WIX is its match offhand tho.
It is and there should be a heavy spring at the bottom to press the filter against the lid.
Nice find!
