| | | Forums66 Topics128,268 Posts1,058,378 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#79884 07/11/2007 3:02 AM | Joined: Dec 2003 Posts: 62 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 62 | I'm one of those that when I put things back together, I always try to user all new fasteners. In the process of putting together my 235, and want to replace the 2 screws that hold the cam thrust plate on, I found 2 SS screws at my favorite hardware store, but they were out of the original style inner locking lock nuts, will the outer locking nuts work just as well? Should I use loctite on the threads of the new screws? I've read the threads on using stainless screws & bolts, and possible thread problems. Am I going in the wrong direction? Thanks! | | |
#79885 07/11/2007 3:37 AM | Joined: Apr 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 275 | I like to use button head allens, forget the washer & use threadlocker instead. Feel like hopefully I'm getting a better grade of bolt & can tighten it up better. Doug | | |
#79886 07/11/2007 4:28 AM | Joined: Mar 2006 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 72 | Shucks, thought I was the only one who liked using SS allen bolts on an engine. | | |
#79887 07/12/2007 12:24 AM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I would caution on the use of SS bolts where high grade #5 or #8 are called for. Stainless bolts are generally made of softer material. They may look pretty but are they correct for your job..? Be sure what grade they are. | | |
#79888 07/12/2007 2:43 PM | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | I agree with Moneypit ...check the Grade of your SS bolts if ya usin em in a critical area !..now for stuff that dont mean your life in your hands SS from the Hardware is ok an is 1 less thing to worry abought rustin ..I replaced a lot of fasteners i dont want to rust with SS ...but they are just holdin sheetmetal an STUFF ...but for steerin gear an such grade 8 bolts an paint . | | |
#79889 07/12/2007 6:53 PM | Joined: Mar 2006 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 72 | I mainly use them for engine covers, fuel pumps, water pumps, starters and generator attechments. Wouldn't dream of using 'em for anything important like head bolts, let alone steering, etc. | | |
#79890 07/12/2007 7:50 PM | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | Catman
Shamrock Bolt & Screw Should have any grade SS bolt or nut you need. Their a commercial dealer but will sell small orders to walk ins, I have used them many times for odd or unusual bolts. Phone 862-7078 | | |
#79891 07/13/2007 3:29 AM | Joined: Dec 2003 Posts: 62 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 62 | I knew you guys would have the answer! ttodd, I will check with Shamrock for at least a grade 8, even if not SS since it won't be seen, last thing I need is a loose cam. Thank you all! | | |
#79892 07/13/2007 3:48 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | From what I understand, they don't make grade 8 in stainless, because of how soft it is. leave the stainless for sheetmatal and non-critical parts, like what the others said. And don't forget, anything you do use stainless on, coat the threads with anti-seize. If you don't, the threads will gall, ending up with a broken bolt or karked up threads.
Bill Burmeister | | |
