4 members (wilbur53, klhansen, Steelonsteel, Bill Hanlon), 141 guests, and 2 robots.
Topics128,266
Posts1,058,368
Members48,485
#79884 07/11/2007 3:02 AM
I'm one of those that when I put things back together, I always try to user all new fasteners.
In the process of putting together my 235, and want to replace the 2 screws that hold the cam thrust plate on, I found 2 SS screws at my favorite hardware store, but they were out of the original style inner locking lock nuts, will the outer locking nuts work just as well? Should I use loctite on the threads of the new screws? I've read the threads on using stainless screws & bolts, and possible thread problems. Am I going in the wrong direction? Thanks!
#79885 07/11/2007 3:37 AM
I like to use button head allens, forget the washer & use threadlocker instead. Feel like hopefully I'm getting a better grade of bolt & can tighten it up better. Doug
#79886 07/11/2007 4:28 AM
Shucks, thought I was the only one who liked using SS allen bolts on an engine.
1947 Chevy 6400 Wrecker
Old Stovebolts don't leak oil
They just mark their territory
#79887 07/12/2007 12:24 AM
I would caution on the use of SS bolts where high grade #5 or #8 are called for. Stainless bolts are generally made of softer material. They may look pretty but are they correct for your job..? Be sure what grade they are.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#79888 07/12/2007 2:43 PM
I agree with Moneypit ...check the Grade of your SS bolts if ya usin em in a critical area !..now for stuff that dont mean your life in your hands SS from the Hardware is ok an is 1 less thing to worry abought rustin ..I replaced a lot of fasteners i dont want to rust with SS ...but they are just holdin sheetmetal an STUFF ...but for steerin gear an such grade 8 bolts an paint .
1952 Chevy Shortbed
Photos in Photobucket
#79889 07/12/2007 6:53 PM
I mainly use them for engine covers, fuel pumps, water pumps, starters and generator attechments. Wouldn't dream of using 'em for anything important like head bolts, let alone steering, etc.
#79890 07/12/2007 7:50 PM
Catman
Shamrock Bolt & Screw Should have any grade SS bolt or nut you need. Their a commercial dealer but will sell small orders to walk ins, I have used them many times for odd or unusual bolts. Phone 862-7078
#79891 07/13/2007 3:29 AM
I knew you guys would have the answer! ttodd, I will check with Shamrock for at least a grade 8, even if not SS since it won't be seen, last thing I need is a loose cam. Thank you all!
#79892 07/13/2007 3:48 AM
From what I understand, they don't make grade 8 in stainless, because of how soft it is. leave the stainless for sheetmatal and non-critical parts, like what the others said.
And don't forget, anything you do use stainless on, coat the threads with anti-seize. If you don't, the threads will gall, ending up with a broken bolt or karked up threads.
Bill Burmeister
