7 members (Johnny Rib, dwreills, Gdads51, Rexville48, Wayne67vert, Wickedbass, Peggy M), 147 guests, and 3 robots.
Topics128,036
Posts1,055,460
Members48,422
#798121 11/15/2011 3:00 PM
As I get closer to the finish I have several strange parts.
PART 1
PART 2
~Jim
#1 is an inner door bottom weatherstrip retainer.
#2 is a cab to running board seal retainer.
You Tube
Curt, the pic below is what I used for the door seal retainer.
I suspected the other was the running board seal as the holes matched up. I can't see, however, how it attaches.
INNER DOOR SEAL & RETAINER
~Jim
If you feel under the cab right above the running board on the inside ledge there is a splash rubber that keeps water and dirt from going on your running board.Part #2 sheet metal screws to the top of that lip and holds the rubber splash,it screws in from the top down and is a pain to screw in. I did mine before I put the cab on the frame.
Part #1 screws to the bottom of the door and holds the weather stripping thats around the door in place.
I don't have my truck here it's put away for the winter,if I did I could post some pics.
Pete
Curt's right on both of them. I'll get you a picture of the inner door bottom weatherstrip retainer with the rubber installed.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
here is a bad pic
...pic...
...pic...
Good Luck
Keep in mine I had to replace a LOT of metal in this area so I drilled holes and used either a 3/16 bolt or 1/4".
Its just another shot as info of the running board splash piece.
...and its on my panel and not a pickup.
http://i140.photobucket.com/albums/r19/LutherParris/52Panel/000_0277-1.jpg
I see that it screws from the bottom up ,I wish my truck were here since memory is NOT what it was.
Pete
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Originally Posted by johntsmith
My understanding is that the inside of the door bottom should look like this.
You Tube
Thanks guys, you've pull a thorn out of my paw. Alvin, I believe I'll do like you and use bolts. My philosophy has always been that if a nail would do, use a screw, and if a screw would do, use a bolt; it's always better to "overdo it than to do it over".
~Jim
This is the way the original bottom door seals were on the door before the restoration, and I believe they were original, but in almost 60 years who knows???
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Curt B is right thats the way the door bottom should look like it does on my 52 anyway.
http://i176.photobucket.com/albums/w186/curt160/Weatherstrip/Picture182.jpg
Pete
Pete
Where's the rubber seal?
I went to my storage unit and looked at my 2 spare doors and they have the rubber installed the way I do. Could there be a difference in the seals from '52 to '53?
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
I suppose that's possible. Without a assembly manual from those years it's hard to tell. I will say the GM parts book from 40 something to 54 shows the door like Pete52's door. However the book is a bit short on pictures and some show different year models only.
~Jim
