0 members (),
31
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | As I get closer to the finish I have several strange parts. PART 1 PART 2
~Jim
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | #1 is an inner door bottom weatherstrip retainer. #2 is a cab to running board seal retainer.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Curt, the pic below is what I used for the door seal retainer. I suspected the other was the running board seal as the holes matched up. I can't see, however, how it attaches. INNER DOOR SEAL & RETAINER
~Jim
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | If you feel under the cab right above the running board on the inside ledge there is a splash rubber that keeps water and dirt from going on your running board.Part #2 sheet metal screws to the top of that lip and holds the rubber splash,it screws in from the top down and is a pain to screw in. I did mine before I put the cab on the frame.
Part #1 screws to the bottom of the door and holds the weather stripping thats around the door in place.
I don't have my truck here it's put away for the winter,if I did I could post some pics.
Pete
| | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Curt's right on both of them. I'll get you a picture of the inner door bottom weatherstrip retainer with the rubber installed.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | here is a bad pic ...pic... ...pic... Good Luck | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Keep in mine I had to replace a LOT of metal in this area so I drilled holes and used either a 3/16 bolt or 1/4". Its just another shot as info of the running board splash piece. ...and its on my panel and not a pickup. http://i140.photobucket.com/albums/r19/LutherParris/52Panel/000_0277-1.jpg | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I see that it screws from the bottom up ,I wish my truck were here since memory is NOT what it was.
Pete | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 |
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | My understanding is that the inside of the door bottom should look like this.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Thanks guys, you've pull a thorn out of my paw. Alvin, I believe I'll do like you and use bolts. My philosophy has always been that if a nail would do, use a screw, and if a screw would do, use a bolt; it's always better to "overdo it than to do it over".
~Jim
| | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | My understanding is that the inside of the door bottom should look like this.This is the way the original bottom door seals were on the door before the restoration, and I believe they were original, but in almost 60 years who knows???
| | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Where's the rubber seal? I went to my storage unit and looked at my 2 spare doors and they have the rubber installed the way I do. Could there be a difference in the seals from '52 to '53?
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I suppose that's possible. Without a assembly manual from those years it's hard to tell. I will say the GM parts book from 40 something to 54 shows the door like Pete52's door. However the book is a bit short on pictures and some show different year models only.
~Jim
