Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (51sub), 187 guests, and 7 robots.
Topics128,288
Posts1,058,578
Members48,492
#796028 11/08/2011 1:39 AM
This is probably a stretch...
Anyone know if Fenton or Williams headers will fit on a 216 with the InnerLine block mounted oil filter?
Its really hard to tell just from pictures.
Anyone?
...Anyone located in MO near St.L who has Fenton headers? Shoot me a PM. If I could get a look at em in person I could probably tell how close they run to the oil distributor plate and If I could route the piping around the InnerLine filter.
No one?
FWIW, I found some older posts in the "Intakes" thread that suggest the Fentons will clear the InnerLine filter.
Thats enough info for me to take a stab.
I am not sure i understand your question but i have fenton headers and for awhile i used a original canister filter.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
I've never heard of an InnerLine filter before and had to look it up.
Is this right?
It sure looks like it would be very close at minimum. If it doesn't get in the way of the exhaust pipes, could you machine an extension to move it outward farther?
Jeff
My 1953 Chevrolet
1947.1 Gallery
1 Offline
We used the InnerLine units on our older 235 and 261 Chevy sixes in our Fire Department. They were great to work with and did the job they were supposed to do and sure much easier and less messy when being changed out.
Normbc9
I have never used or seen an Inner-Line filter in place under/behind a set dual-exhaust manifolds, but I agree with Jeff, it looks like it would be tight, at best.
What characteristic of this filter would make it easier to replace than other types of by-pass filters?
If it fits behind a set of dual exhaust manifolds/headers, you might find that you would have limited room for manipulating whatever type of filter-element needs to be replaced.
BLUEMEANIE is correct in his original post "Its really hard to tell just from pictures." Maybe someone who has one installed with dual exhaust manifolds/headers will respond?
Normbc9
How/Where did you attach the Inner Line units shown above on a 261 block?
Is this right?
Jeff
Yes, that is correct.
I've read that the front Fenton header exits at the same spot the single GM header exits and the rear Fenton exits behind it, closer to the firewall. If this is correct the pipes should clear the InnerLine filter.
What I read actually said that this is why the original Fentons used both a donut and a flat gasket, meaning that you could reuse the original single pipe from the front header and you would only have to have a new pipe bent for the rear header.
