0 members (),
116
0
Mod | | | Forums66 Topics128,127 Posts1,056,679 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2003 Posts: 49 Member | | Member Joined: Mar 2003 Posts: 49 | Hello Bolters, I am thinking about getting my gas tank cleaned and sealed by a local radiator shop but they want $200 to do it. Does anyone sell or know of a gas tank that will fit in the origional location. I dont want to lose the spare tire carrier in the back. Will a later suburban or blazer tank fit? Please help if you can. Thanks, Bill | | | | | Joined: Nov 2011 Posts: 17 New Guy | | New Guy Joined: Nov 2011 Posts: 17 | you might try classic chevy truck parts of america and see what they have. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Spectra makes the vintage tanks available and they don't list one for the TF panel/burb .... I've heard that a later Blazer tank can be made to fit, but you may be best off getting your original done, or doing it yourself Bill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | You will spend much more fitting straps,filler tube and the cost of a tank than $200. If they do it correctly it is way worth $200. Make sure he has done many gas tanks and find out the different steps he takes. Just "cleaning" in his radiator tank and check for leaks is not $200. Fixing leaks, Special tank cleaning solution, then an inner tank coating and clean the outside, is what you want for $200. All this can be done as Squeeze said by the use of an aftermarket kit. Eastwood has a kit for this $80. If you don't have any holes in it, that should work. I don't think the radiator shop will weld a gas tank anyway. If it does have holes, that will require the proper crazy guy. I don't have ANY faith in ANY leak sealers of ANY type.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Around here an overnight tank dip is 40-50 bucks. Add 75-85 for a kit to seal it.
bartamos, I've had lots of success the past 15 years with sealers for myself and my buddies. I've always used the POR15 kit and had no problems. I currently have one in the 37 that has been in it for 13 years and you can see down in it. Still looks good. I will say all applications have its own set of circumstances and I'm sure who/when/what/how on the preparations go a long way to as well as the actual condition of the tank. I guess it boils down to good common sense/judgement. If the pocketbook can stand it new is always better IF available. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Chipmunk, you used sealer. Did you use it to seal a leak? My dislike stems from sealers that I have used to seal a leak somewhere and they don't work for long. Not speaking of a sealers used to coat something.
