7 members (Southerntruck, 1955 1 Series, cmayna, Cletus1950, Wayne67vert, Otto Skorzeny, Hanks custodian),
95
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,156 Posts1,056,871 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2011 Posts: 21 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 21 | I have a '50 chevy truck with a '59 235 engine. The gage in the dash is 0-30. Should I use a 0-60 gage since the '59 235 is a high pressure engine or can I use the 0-30 gage? Will it hurt the 30 psi gage to run higher pressure to it? The engine has a complete rebuild and new oil pump.
Any help is appreciated
Thanks | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There are thousands of cars and trucks running the 30 psi gauge with a 235, with no problems.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | "high pressure" is a misnomer, 'full pressure' is what's meant - a 59 would have had a 60# gauge as provision for the V8, but any 235 will hardly reach 30psi even cold, you won't have a problem
Bill | | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | I have a 30 psi gauge in my truck while running a full pressure 261. When I run the truck it pegs the needle and at idle on a hot day after some driving it will drop to 20 psi.
In the end it's lack of oil pressure that is detrimental to these engines so your existing gauge will work just fine
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Jul 2011 Posts: 21 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 21 | I am going to go with the 30 psi gage since it still works and is already in the cluster.....Thanks for the input. | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | My 1953 235 full pressure powerglide engine runs 40 PSI hot or cold at speed, and 20 psi at idle. Kurt | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Just as info.... since i put a v8 in my 37 but wanted to keep the original guages I had Mike (D&M Restorations) calibrate my old guage to read double....when the guage says its 15lb its really 30 and when it shows 30 its really 60....works for me. | | |
