| | | Forums66 Topics128,109 Posts1,056,266 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 6 New Guy | | New Guy Joined: Nov 2011 Posts: 6 | Does anyone have information about putting power steering on a '51-3100? I know there's kits for this for $800.00, but I've heard you can get parts off later vehicles to convert the '51 to power steering. So what parts are needed and what's involved in the change over? Thanks | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | What steering column are you going to use? In general terms...a saginaw gear box, rebuilt available from most discount part stores. I used a 76 pickup steering box.($116) (some use a toyota box), a kit http://www.classicparts.com/1947-59-Power-Steering-Conversion-Kit/productinfo/76-977/ (about $95)with adjustable steering link,steering arm and bushings. You'll need a pitman arm of the right vintage. (impala,malibu...with about 5 1/2" between holes. A couple universal joints,a length of double "D" steering shaft....and naturally a power steering pump and a cooler. I like the cooler in the bottom of a radiator. Also don't forget to use the updated tie rod ends. The old ball and socket are good but I just don't feel good riding around mountain curves with the ball and socket. (new ends available for about $50 for the pair) There are a couple pics in my photo bucket if you'd like to look.... any questions PM me. (I'll be out of town until Monday) Hope this gets you started in the right direction. This might help. Here is some reading to help you out. http://www.classictruckshop.com/t1.phpand http://www.classicperform.com/tech_articles/Power-Steering-Trucks/Power-Steering-Trucks.htm | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I'm generally uninformed about this subject mostly because I don't see a need for PS in my case. But I have friends that would have to have it because of health reasons so I've been keeping an open ear for their sake. From what I’ve seen so far it sounds like no one has come up with a conversion that uses the original steering column and linkage. It appears that all of the PS conversions entail replacing the entirely steering system from the wheel on down, is that true?
DG.
Denny G Sandwich, IL
| | | | | Joined: Jul 2007 Posts: 328 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 328 | Woody
I used the CPP kit. It uses the late chevy p/u power steering box. They sell a whole kit...or, just the components you need. It mounts the box outside of the frame and forward. It works great. I have it on my 51 panel and steering is effortless. It requires cutting of the existing steering arm, relocating the shock mount ( no big deal) and using the supplied new pitman arm and adjustable steering arm. You can modify the stock column to attach, or install a later model one if this is an engine/trans conversion you're doing.
With the added forces of the power set up, it is HIGHLY recommended that you install the later style tie rod ends, a stouter tie rod ( they sell a 1" unit), and the 1 1/8" stabilizer bar. Ensure the king pins are up to snuff before all this!
Additionally, I installed a steering stabilizer on the front axle (easy); to help calm everything down up there. my 2 cents! mike
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | You can have power steering and keep every piece of the factory stuff except the drag link. A power assist cylinder is mounted with one end attacthed to the axle and the other to the tie rod. No geometry or anything else is changed except steering effort. It must not be a bad system since Chevy cars used it up through 64, Mustang through 70, and the Corvette untill almost 1980. It might still be used for industrial applications.
Evan
