| | | Forums66 Topics128,288 Posts1,058,577 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | This is probably a stretch...
Anyone know if Fenton or Williams headers will fit on a 216 with the InnerLine block mounted oil filter?
Its really hard to tell just from pictures. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | Anyone?
...Anyone located in MO near St.L who has Fenton headers? Shoot me a PM. If I could get a look at em in person I could probably tell how close they run to the oil distributor plate and If I could route the piping around the InnerLine filter. | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | No one?
FWIW, I found some older posts in the "Intakes" thread that suggest the Fentons will clear the InnerLine filter.
Thats enough info for me to take a stab. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I am not sure i understand your question but i have fenton headers and for awhile i used a original canister filter.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I've never heard of an InnerLine filter before and had to look it up. Is this right?It sure looks like it would be very close at minimum. If it doesn't get in the way of the exhaust pipes, could you machine an extension to move it outward farther? Jeff | | | | | Joined: Apr 2011 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 181 | We used the InnerLine units on our older 235 and 261 Chevy sixes in our Fire Department. They were great to work with and did the job they were supposed to do and sure much easier and less messy when being changed out. Normbc9 | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I have never used or seen an Inner-Line filter in place under/behind a set dual-exhaust manifolds, but I agree with Jeff, it looks like it would be tight, at best.
What characteristic of this filter would make it easier to replace than other types of by-pass filters?
If it fits behind a set of dual exhaust manifolds/headers, you might find that you would have limited room for manipulating whatever type of filter-element needs to be replaced.
BLUEMEANIE is correct in his original post "Its really hard to tell just from pictures." Maybe someone who has one installed with dual exhaust manifolds/headers will respond?
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | We used the InnerLine units on our older 235 and 261 Chevy sixes in our Fire Department. They were great to work with and did the job they were supposed to do and sure much easier and less messy when being changed out. Normbc9 How/Where did you attach the Inner Line units shown above on a 261 block? | | | | | Joined: Mar 2011 Posts: 940 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 940 | I've never heard of an InnerLine filter before and had to look it up. Is this right?It sure looks like it would be very close at minimum. If it doesn't get in the way of the exhaust pipes, could you machine an extension to move it outward farther? Jeff Yes, that is correct. I've read that the front Fenton header exits at the same spot the single GM header exits and the rear Fenton exits behind it, closer to the firewall. If this is correct the pipes should clear the InnerLine filter. What I read actually said that this is why the original Fentons used both a donut and a flat gasket, meaning that you could reuse the original single pipe from the front header and you would only have to have a new pipe bent for the rear header. | | |
