| | | Forums66 Topics128,070 Posts1,055,892 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 190 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2006 Posts: 190 | After finishing my brakes today I could not help notice that my front brake backing plates have no holes to make adjustments. Does this mean I have to pull the drums every time I need to adjust them, or should I put some holes in them like the rear brakes. I have never seen a backing plate with no holes before. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Debra, I'm not sure about this. I checked the online manual and seen nothing to help..... BUT, isn't the holes in the drum so you can get to the adjusting wheel through it??? I can't remember and my personal shop manual is on loan. Check the drum and let us know. They may be a "knock out" in the drum but surely by now, after all these years someone would have knocked them out!!
| | | | | Joined: Jul 2006 Posts: 190 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2006 Posts: 190 | Yea I have checked my manual..no help and the Aduels manual from the period. Nothing on no adjustment holes. So I will get my drill and dremel out and put some oval holes and rubber plugs. I was really just wondering if any one has ever seen backing plates without the oval holes. I am so glad to be feeling so good now that the 2 year sinus thing is resolved and have energy to get back to the old girl. Will be nice to drive her in and out of the garage instead of pushing. | | | | | Joined: Apr 2010 Posts: 244 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 244 | My '37 drums have holes for adjusting from the drum side (You have to pull the wheel to adjust the brakes). Pull a wheel and check before you mess with the backing plates. | | |
