2 members (Gdads51, 1 invisible),
92
0
Mod | | | Forums66 Topics128,052 Posts1,055,743 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2011 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 81 | I own two 65 C10 and there is no way I can affort to upgrade both brakes sets anytime soon. So, what can I do that is inexpensive to improve the original brakes?
Thank you Tim | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Just do a thorough rebuild on them. Overhaul/replace wheel cylinders/master cylinder as necessary, replace the hoses, flush the lines (replace if in poor condition), and recondition the drums (If in spec, otherwise replace them). Properly adjusted, the drum brakes will be fine. If you can, look for shoes with an "FF" code. Those are the high friction shoes, will get you more stopping power. Other than adding a booster, there's not really much more than you can do with drums.
Bill Burmeister | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | If it were me I'd replace ALL of the brake lines if they are still the original ones (both steel and rubber). Old steel lines will rust from the inside out (DOT-3 wicks water) and the rubber will swell on the inside. Both will look fine on the outside! Replacing the lines is cheap and easy to do Be safe! Mike B  | | | | | Joined: Dec 2008 Posts: 319 Shop Shark | | Shop Shark Joined: Dec 2008 Posts: 319 | I'll agree with Bill and Mike. Just go through the entire system...it doesn't cost much at all. I like my big drums!
cm If you can't fix it with a hammer and screwdriver, you need a bigger hammer.1965 Chevy C10 | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Nothing wrong with drum brakes if set up correctly. A few years ago, I bought drums for around $25 from a local parts store for my '66. | | |
