8 members (Joe H, Joe Lowe III, Oswald, frogfarmer, Cosmo, DaveV, Shade Baby, 1 invisible), 67 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
#795735 11/06/2011 11:19 PM
I own two 65 C10 and there is no way I can affort to upgrade both brakes sets anytime soon. So, what can I do that is inexpensive to improve the original brakes?
Thank you
Tim
timmc #795737 11/06/2011 11:24 PM
Just do a thorough rebuild on them. Overhaul/replace wheel cylinders/master cylinder as necessary, replace the hoses, flush the lines (replace if in poor condition), and recondition the drums (If in spec, otherwise replace them). Properly adjusted, the drum brakes will be fine. If you can, look for shoes with an "FF" code. Those are the high friction shoes, will get you more stopping power. Other than adding a booster, there's not really much more than you can do with drums.
Bill Burmeister
If it were me I'd replace ALL of the brake lines if they are still the original ones (both steel and rubber). Old steel lines will rust from the inside out (DOT-3 wicks water) and the rubber will swell on the inside. Both will look fine on the outside! Replacing the lines is cheap and easy to do
Be safe!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I'll agree with Bill and Mike. Just go through the entire system...it doesn't cost much at all.
I like my big drums!
cm
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
Nothing wrong with drum brakes if set up correctly. A few years ago, I bought drums for around $25 from a local parts store for my '66.
