10 members (klhansen, papas52, baldeagle, 1955 1 Series, KEVINSKI, Hotrod Lincoln, TUTS 59, Gdads51, Dusty53, Lonnie),
178
Mod | | | Forums66 Topics128,165 Posts1,056,999 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | While troubleshooting an intermittent problem a few weeks ago I opened the glass bowl on the fuel pump and checked for chunks of rust. Since closing it again I have had a bit of gas leakage from around the base of the bowl. It has a 5 year old rubber gasket. At first I just cranked down on the locking screw hoping it would eventually seal, and it did get better, but it is still seeping. My garage smells of gas, and I do not like the smell or the danger. Any tips on getting that gasket to seal good and tight? It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | | | | Joined: May 2005 Posts: 235 Shop Shark | | Shop Shark Joined: May 2005 Posts: 235 | The gasket in mine has distorted pretty badly. I clamp the fuel line so no gas gets into the filter then carefully align the gasket and the glass. Over tightening won't help.. Stopping the gas flow means you don;t have to rush to get things seated properly. Hope this helps.
Jeremy | | | | | Joined: May 2006 Posts: 423 'Bolter | | 'Bolter Joined: May 2006 Posts: 423 | I've got a metal line from the tank to the pump, but the tank does have the shutoff valve, and that helps stop the gas flow. But the fuel seems to run back from the carb, too, so I lose a bunch of gas in any event. My gasket does not seem to be so beat up. I suspect it has a valley pressed into it which is no longer lined up with the bowl - or in other words - the gasket has lost its elasticity. The original gasket must have been cork, and I wonder if cork might be better. I've got some cork material lying around, maybe I'll try making a new gasket. It may not be the easy way, but it is the Cowboy Way - Ranger Doug Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri 1953 Chevy 3100 1960 Volvo PV 544 1941 Chevrolet Special Deluxe | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Cork will seep as well. Did you try turning the gasket over? You might also look for a seller of nitrile gasket material.
| | | | | Joined: Apr 2006 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 62 | I got my new gasket from a John Deere dealer, but I would guess there are not many of them in Sweden. As noted, I would try to make my own. Stan | | | | | Joined: Oct 2011 Posts: 46 New Guy | | New Guy Joined: Oct 2011 Posts: 46 | you can get the gasket at your local napa auto parts store...i got mine there... it just like original made of cork...just reized your in sweden ....you can order online link below
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?A=FPG5019_0165551929&An=599001+101955+50014+2014099&Ar=AND(P_RecType%3aA)
