4 members (Rich'sToys, dt235sd, GMJim, 2-Ton), 145 guests, and 4 robots.
Topics128,167
Posts1,057,017
Members48,458
#795655 11/06/2011 6:19 PM
While troubleshooting an intermittent problem a few weeks ago I opened the glass bowl on the fuel pump and checked for chunks of rust. Since closing it again I have had a bit of gas leakage from around the base of the bowl. It has a 5 year old rubber gasket. At first I just cranked down on the locking screw hoping it would eventually seal, and it did get better, but it is still seeping. My garage smells of gas, and I do not like the smell or the danger. Any tips on getting that gasket to seal good and tight?
It may not be the easy way, but it is the Cowboy Way - Ranger Doug
Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri
1953 Chevy 3100
1960 Volvo PV 544
1941 Chevrolet Special Deluxe
The gasket in mine has distorted pretty badly. I clamp the fuel line so no gas gets into the filter then carefully align the gasket and the glass. Over tightening won't help..
Stopping the gas flow means you don;t have to rush to get things seated properly.
Hope this helps.
Jeremy
1950 Chevy 3800 1-Ton Long Bed
More pix on Flickr
Sold all the bikes, leaving California behind.
I've got a metal line from the tank to the pump, but the tank does have the shutoff valve, and that helps stop the gas flow. But the fuel seems to run back from the carb, too, so I lose a bunch of gas in any event. My gasket does not seem to be so beat up. I suspect it has a valley pressed into it which is no longer lined up with the bowl - or in other words - the gasket has lost its elasticity. The original gasket must have been cork, and I wonder if cork might be better. I've got some cork material lying around, maybe I'll try making a new gasket.
1953 Chevy 3100
1960 Volvo PV 544
Ex Hall Monitor
Ex Hall Monitor
Cork will seep as well. Did you try turning the gasket over? You might also look for a seller of nitrile gasket material.
Tiny #795720 11/06/2011 10:20 PM
I got my new gasket from a John Deere dealer, but I would guess there are not many of them in Sweden. As noted, I would try to make my own.
Stan
you can get the gasket at your local napa auto parts store...i got mine there... it just like original made of cork...just reized your in sweden ....you can order online link below
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?A=FPG5019_0165551929&An=599001+101955+50014+2014099&Ar=AND(P_RecType%3aA)
1948 Chevy 5 Window 1/2 Short Bed
1969 Dodge Coronet SUPER BEE 383 Ramcharger
1949 Bentley Mark VI Standard Saloon
http://imageshack.us/photo/my-images/695/dsc04398mm.jpg/
