4 members (Gdads51, Hotrod Lincoln, Bill Hanlon, 1 invisible), 100 guests, and 2 robots.
Topics128,131
Posts1,056,369
Members48,441
Have removed the rusty windshield on 36 suburban. Wondered if the black color should be painted or powdercoated..after media blasting. Artillery wheels will be powdercoated in black some time down the road.
1936 Chevy Suburban Carryall
1941 Chevy Woodie with Cantrell body
1936 Low Cab Chevy Pickup
1941 Spec Deluxe Chevy Coupe.
1953 Pontiac Catalina hardtop
More pix on Flickr
powder coat it...... paint chips and fades to easy and its to easy for rust to get started under small blemishes. I think a tougher coating will last.... and if desired later it can be scuffed and painted over.
EDIT: this is just my "opinion"!!
My windshield frame is not rusted. So I primed with self etching primer and will be painting to match what will be pained on the truck. One thing with powder coating (which is good) is that powder coating will not give the same finish. If you are worried about chipping and cracking due to flexing there is an additive you can add to your final paint (usually used on plastic bumper paint) to keep this from happening. Check with your local auto paint store.When I was painting bikes (especially the imports with lots of plastic we used it quite a bit). Just ask for flex additive.
1937 Chevy 1/2-Ton
