| | | Forums66 Topics128,010 Posts1,055,303 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 121 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 121 | how can you tell the difference between a regular rochester and a 261 rochester ? i would like to find one for my 261 engine | | | | | Joined: Apr 2009 Posts: 121 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 121 | | | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | By tag number if the tag is present.
The internal venturi size on the 261 carb is larger than on the 235.
I do not have measurement/tag number.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | The General rule of thumb is that a 261 had a 1 11/16" throttle bore and the 235 had a 1 9/16" bore. Of course there is always exceptions to the rule. I read somewhere that there was over 140 different models of the rochester 1bbl. | | | | | Joined: Apr 2009 Posts: 121 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 121 | dam thats a lot of different models . i really want to find two 261 carbs | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Try plugging your engine year and size into the NAPA site and see what they show as available. Their's will be pricey, but it will give you an idea what to look for elsewhere.
Drew
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | From what I have learned rebuilders decided that the small difference would not be noticeable or worth the effort of stocking another variation and list the 235 size carb for replacement on 261’s. NOS is about the only possibility and my experience matches Carbking and Whitedog in that they can be identified by measuring the throttle bore.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | If you are wanting two 261 carbs for a dual manifold, dual 216's may be the way to go. From what I've been told (by the guys here and elsewhere) dual 216/early235 carbs are easier to tune and calibrate. If you are wanting a single carb application, finding a carb from a 292 may be alot easier than the 261. | | | | | Joined: Apr 2009 Posts: 121 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 121 | well i want two 261 carbs because i have two 261 engines but i just got a tickstun dual intake i think im going to use it on my 54 . | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Good luck, sounds like a cool project.
