6 members (frogfarmer, pauld, Shaffer's1950, lumbersawyer, BC59, 1 invisible), 185 guests, and 5 robots.
Topics128,264
Posts1,058,358
Members48,485
#790105 10/19/2011 5:43 AM
how can you tell the difference between a regular rochester and a 261 rochester ? i would like to find one for my 261 engine
big_dan_1950 #793896 10/31/2011 9:24 AM
ttt
big_dan_1950 #793921 10/31/2011 1:11 PM
Carburetion specialist
C Online: Content
By tag number if the tag is present.
The internal venturi size on the 261 carb is larger than on the 235.
I do not have measurement/tag number.
Jon.
The Carburetor Shop
carbking #794168 11/01/2011 6:05 AM
The General rule of thumb is that a 261 had a 1 11/16" throttle bore and the 235 had a 1 9/16" bore. Of course there is always exceptions to the rule. I read somewhere that there was over 140 different models of the rochester 1bbl.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Whitedog #794173 11/01/2011 6:39 AM
dam thats a lot of different models . i really want to find two 261 carbs
big_dan_1950 #794202 11/01/2011 1:48 PM
Try plugging your engine year and size into the NAPA site and see what they show as available. Their's will be pricey, but it will give you an idea what to look for elsewhere.
Drew
DrewP #794212 11/01/2011 2:21 PM
From what I have learned rebuilders decided that the small difference would not be noticeable or worth the effort of stocking another variation and list the 235 size carb for replacement on 261’s. NOS is about the only possibility and my experience matches Carbking and Whitedog in that they can be identified by measuring the throttle bore.
You Tube
DrewP #794214 11/01/2011 2:24 PM
If you are wanting two 261 carbs for a dual manifold, dual 216's may be the way to go. From what I've been told (by the guys here and elsewhere) dual 216/early235 carbs are easier to tune and calibrate. If you are wanting a single carb application, finding a carb from a 292 may be alot easier than the 261.
"The Fake Truck"
Whitedog #794513 11/02/2011 8:39 AM
well i want two 261 carbs because i have two 261 engines but i just got a tickstun dual intake i think im going to use it on my 54 .
big_dan_1950 #794918 11/03/2011 5:22 PM
Good luck, sounds like a cool project.
"The Fake Truck"
