2 members (papas52, carbking),
69
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#79257 06/26/2007 10:20 PM | Joined: Nov 2001 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 111 | Is anyone familiar with the Mallory Unilite distributor? I have one on my 51 Chevy with a 350, it was on it when I bought it. I have chased a skip or miss in this thing for a couple of days. I thought I found it when I found a bad plug wire but it still skips. It sounds like a steady and regular missfire. Will the Unilite ignition module cause it to skip or does it just go out all at once with no fire at all???? thanks!! Mitchell
54 Chevy 5 window - 46 Chevy 1/2 ton
#79258 06/26/2007 11:15 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If it,s electronic it,s not likely to miss on only one cyl. If a plug wire was open it very likely has burned the dist cap. Take a hard look inside for carbon tracks. Kind of look like a jagged pencil mark. The plug could be fouled from not fireing. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#79259 06/26/2007 11:23 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I have one on my 57' BelAir engine and it either works or doesn't work. I agree with Wrenchbender, it's all or nothing with most electronic gadgets ans all indications are that the Unilite is no different. | | |
#79260 06/26/2007 11:50 PM | Joined: Nov 2001 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 111 | How obvious will that crack in cap be? Do I look with a magnifying glass or just with good light? If cracked, is that a special cap for the Unilite or does regular cap work? As you can tell this is my first experience with a Unilite. thanks Mitchell
#79261 06/27/2007 2:33 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Could very well be a burned cap. It can also be a burned rotor. I had mine do that. You willneed to get a cap and rotor for a Unilite, standard parts do not fit. Any mallory dealer can get them for you. One more thing. From my own experience, if you have the one without the vacuum advance, give it a little more advance on the base timing. I found that mine was much happier with 15 degrees advance over the stock setting.
Bill Burmeister | | |
