0 members (),
102
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 128 | Hey, guys. Just moved my '46 two ton from Florida to Colorado and was wondering if I should be concerned about the block freezing and cracking this upcoming winter. It's garage kept, but no heat. Anyone know lowest temp the antifreeze/block can take before trouble starts? It has a '52 235 in it. Here in Denver, it can get to around 15 degrees, but not for more than a day or so. Are block warmers more trouble than they're worth? Thanks.
Adam
1946 2 Ton Flatbed
| | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Adam, it depends on the ratio of coolant to water. We protect our engines to 40 below. We don't use block heaters unless we need to start them. It's easy to check your coolant for frost protection, with a hydrometer or anti-freeze tester. And yes, you should be concerned, a frozen block is scrap. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | make sure it has good coolant in it and it should be good to go... I believe it would have to get much colder then that to even have a concern unless you had pure water in it... check the coolant and see what the bottom number is...........dont know why you would need a block warmer for that type of temp Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | sorry Leo, you b eat me to it...lol Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Apr 2004 Posts: 438 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 438 | Adam, I'll ditto Leo's post. I live in the mountains in Utah and we also test our antifreeze to 40 below with an antifreeze tester. I have a oil dipstick heater on my work truck. I don't use it all the time, just when I know the temp is really going to get cold and I need the truck to start. Our car has a block heater, and we only use it shortly before starting on real cold mornings.
Are you planning on driving the truck this winter, or is it being stored? | | | | | Joined: Apr 2004 Posts: 5,070 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,070 | Good time for some folks to be reading this tech tip that was written a while back. Might be of help. Maybe needs update ... if so, email me with what!!!! Peg
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Feb 2009 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 128 | Thanks for the info, fellas. I am planning on driving the truck once or twice a week this winter seeing as how the snow melts by the afternoon here. I will track down an anti-freeze tester and make sure everything is good. The anti-freeze is only a month old and it's the 50/50 pre-diluted kind. If it gets lower than 40 below here, I got a lot more to worry about than my old truck  Adam
1946 2 Ton Flatbed
| | | | | Joined: Feb 2010 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 54 | Don't forget the drain on the left side of the block. If you do not get all of the water out it may give you trouble.
Monroe McKill
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Block heaters are not for preventing freezing. They are a cold weather starting aid. | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | Since you plan on driving or starting it at least once a week, you should be fine. Just be sure to follow the cold weather starting procedures, and make sure you have your truck prepped for winter drives!
Dave Baird 1951 Chevy 3803Foot starters are for Stovebolters and people who need a kick in the ...
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Make sure you change oil and get some light weight oil in. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | If you plan on starting it be sure and run it til it is completely warmed up so to get rid of condensation in the oil and burn off water in the exhaust system.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Feb 2009 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 128 | Hold on, hold on... what is the cold weather starting procedure? I read the tech tip column on "Winterizing", but I didn't see anything about the starting procedure or changing the oil weight. I have 15w40 diesel rated oil in it now. Will that do? Any other tips for the winter. Again, I will be driving it at least once a week, but never in the snow.
Adam
1946 2 Ton Flatbed
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I'd put either 10-30 or 5-30 in it. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Apr 2011 Posts: 224 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 224 | The Cold Weather Operation on page 17 of the 1952 Operator's Manual is what I was referring to. The '52 manual might help with some other engine questions you might have later on. {Thanks Tim!}
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | You guys that haven’t changed a tire, boosted a vehicle, or pulled one out of a ditch at minus 30 or better don’t know what you’re missing. Generally minus 25 is the point where if it hasn’t been plugged in for at least a couple hours it won’t go and gas line antifreeze is a must too. Nearly everyone around here has a remote starter and when the temperature drops below minus 15 inside my vehicle the starter will kick in and run it for 5 minutes when it sits outside during the day.
On this topic my father in law has been a farmer all his life and recalls that in the 40’s and 50’s few people had power to their yard to help with warming engine blocks but the truck was the farmer’s lifeline. The stovebolts had a solid reputation that they would start in bitter conditions when Fords and Dodges would refuse which explains why the majority of old farm trucks around here are GM’s.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | A 50/50 antifreeze/water mix protects to -37 degrees F. A 70/30 antifreeze/water mix goes to -69 degrees. Straight ethylene glycol without water in it freezes at +9 degrees, so a 70/30 mix is the strongest solution that's reccomended. Block and/or oil dipstick heaters just help the engine start by keeping the engine slightly warmer than the outside temperature. Diesel engines with 15W40 oil run it year-round without oil-related starting problems, so there's no reason to use a lighter weight oil. The original winter oil that was reccomended for your engine was 20W-20, so the 15 weight cold specification has better flow during cold start conditions than when the engine was new. Jerry
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Straight out of the manual:
From +50 deg to +30 deg F SAE 20 +10 deg to +30 deg F SAE 20W -10 deg to +10 deg SAE 10W -30 deg to -10 deg SAE 10W plus 10% kerosene
With that said I run 15W40 year around. Oils today are much better than when those specs were written.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | And not often mentioned it the matter of availability, the straight weight oils are getting harder and harder to find around here. None of the farm supplies or auto parts stock them anymore. I can find #30 because they are using it in lawn mowers still but #10 and #20 I haven't seen for years. I've been looking for a quart of each for to refill my oil cans with.
DG
Denny G Sandwich, IL
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | My '48 is a daily driver and sits outside. We live in Tropical Montana but it can still get to 20 below or lower in the winter. I use 10W-30 all year round. I have a frost plug heater (500 W, I think) under the intake manifold which is right where you want the heat. It's on a timer and on the coldest days, 4-5 hours is enough. It starts fast, idles well and warms up the defroster faster. When it gets really cold, I also use a magnetic heater (250 W, I think) on the oil pan. I crawl under the truck to put it on but have a 2x2 with a hole drilled in it to pop the heater off in the morning (to help keep my clothes clean). I leave this heater on all night when it's really cold. Here's a pic. Oil Pan Heater.
1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | A 50/50 antifreeze/water mix protects to -37 degrees F. A 70/30 antifreeze/water mix goes to -69 degrees. Straight ethylene glycol without water in it freezes at +9 degrees, so a 70/30 mix is the strongest solution that's reccomended. Good point Jerry. I've seen several instances where people assumed more is better and found out the hard way that the coolant turns to a gel above 70% and quickly destroys engines when it won't flow even on the coldest of days.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Feb 2009 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 128 | Thanks for all the great advice, fellas. Just snowed 4 inches this morning, so I sure am happy I have the truck garage kept. Thanks for the manual links to. There's so much you don't consider with these old trucks...
Adam
1946 2 Ton Flatbed
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | If it's parked inside a garage and idle for the winter I would use 100% antifreeze. You could always put a flood lamp under the hood when it gets really cold.
~Jim
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | As Jerry pointed out straight antifreeze is not the way to go. I needs to be diluted with water to some extent. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Agreed, straight antifreeze would be a mistake IMHO.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | So how much water, a cup, a pint? What does the water do, activate the antifreeze?
~Jim
| | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | So how much water, a cup, a pint? What does the water do, activate the antifreeze? No more than 70% coolant to 30% water. Above that ratio it turns to green jello.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | 50 - 50 mixture is what I've always used. The pre-mix antifreeze that you can buy is 50 -50. http://en.wikipedia.org/wiki/Antifreezethat link should explain the why. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | ... What does the water do, activate the antifreeze? the water is the heat transfer fluid - if the truck were not being used, draining the system would be the correct option, but as it will be run occasionally a proper coolant must be used, 100% antifreeze is not a coolant Bill | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | You mentioned that the antifreeze is 50-50 and that it's only a month old. As long as you know that for sure, you should be good to go. Whenever I get a different vehicle, I usually change antifreeze myself the first year. That way, I know for sure what it's got. | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | If it's parked inside a garage and idle for the winter I would use 100% antifreeze. You could always put a flood lamp under the hood when it gets really cold. Why? | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | good question Vette,
to answer your original question about how long would it take to have a block problem... just depends, if you had no antifreeze it would take about 3-4 days at 25 F and at -25 it would take about 30 min...says the expert
some say a 50/50 mix should be good for -15.... so as long as you have some antifreeze in it I would not worry about it.. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | Look at the mixing chart that's on the back of every antifreeze jug out there- - - - -a 50/50 mix is good for -37 degrees! I believe a 70/30 mix takes the freeze point down to something like -69, colder than it gets in Fairbanks Alaska in the middle of winter. Jerry
