Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Sjm, Tyler Watts), 112 guests, and 2 robots.
Topics128,281
Posts1,058,464
Members48,490
#79110 06/23/2007 2:22 PM
I have a 1948 GMC 3/4 ton with a floor shift 4 speed. I was going to run down to the flaps and pick some gear oil to change it out. What type and weight do you guys use? How much do I need to get? ohwell
Thanks for the info.
#79111 06/23/2007 2:46 PM
90 wt. seems like a qt would do it. It never hurts to have a extra qt on hand for the diff. too. Someone else?
#79112 06/23/2007 3:01 PM
i use 80/90 weight.
many transmission aces recommend non-synthetic because, in theory, the synthetics are too "slippery" to allow the syncros to stick a little and line the gears up. makes sense to me, so i use good old left over dinosaurs.
#79113 06/23/2007 5:07 PM
I think you will need 2-2 1/2 QTS any extra is spare
for the steering box, rear end.
GMC: Get More Cash...
1958 GMC
My Webshots photos
#79114 06/23/2007 5:54 PM
Great.
thanks for the info guys. I will go pick up 3qs of 80-90W non synthetic gear oil.
#79115 06/23/2007 6:08 PM
I have been using synthetic oil in all my vehicles for the last 26 years with excellent results. This includes the engine, transmission ( automatic or standard ), transfer case, and rear end. The gear lube I used to recommend was the 80W-90, but the newer 75W-90 has a higher film strength and has a pour point of -50 degrees.
Bob
55 Cameo 396 TH 400 with overdrive
65 Caliente conv
67 BB Caliente conv
67 Mercury 1 Ton
76 GMC 3/4 ton 454ci
84 Buick Turbo Regal
