8 members (66flea, asilverblazer, J Lucas, Otto Skorzeny, tclederman, Hotrod Lincoln, klhansen, 1 invisible), 136 guests, and 3 robots.
Topics128,185
Posts1,057,294
Members48,467
Page 50 of 177 1 2 … 48 49 50 51 52 … 176 177
Leo Offline
Moderator
Moderator
I think you need to bookmark those pics.
Try it now.
Robert C.
I'm a Genius in the making.
1950 3600
Originally Posted by mobileortho
Makd head way on the hood seam. Got all the holes filled, smoothed, bondo and primed. Not bad for a rookie. grin
Checked out your pics on the HAMB Robert, nice job!
More pix on Flickr.
My truck died last week, stone dead, going down the road almost home. Suspecting an electrical problem, and finding power in all the right places on the coil, I replaced the one-year-old Pertronix ignition with the original points. By gum, it started right up and runs great!
I decided to try the Pertronix because I have had so many problems starting the truck when it's warmed up. The Pertronix sorted that problem out, after installation it started hard both warm and cold. I'll have to return to the hard warm starts and hopefully find another solution to that problem. There's a hundred bucks of Pertronix sitting on the shelf...
It may not be the easy way, but it is the Cowboy Way - Ranger Doug
Beware of the stories you read or tell; subtly, at night, beneath the waters of consciousness, they are altering your world. - Ben Okri
1953 Chevy 3100
1960 Volvo PV 544
1941 Chevrolet Special Deluxe
Went for a nice long drive today (about 100 miles!). New wheels and radial tires are super smooth. Decided to change the oil and lube everything - ready for next cruise.
Robert, that’s great work for an experienced welder, astounding work for a neophyte. Now that you’re an experienced body man you can sharpen your skills on those little beer bruises on the hood. Keep a pictorial record of your work there for us that lack body work skills.
~Jim
I finished up a 1050 mile, 4 day cruise in my Suburban. She ran great. There were 70 some-odd other antique vehicles and we had a ball.
I installed a better hidden antenna.
~Jim
Some blood, sweat and tears were shed but I loaded the '58 onto a lowboy and pulled it home.
The cab was a rat haven... Disgusting creatures, they are!
Sheetmetal isn't so good but I saw a lot of parts I could use for my '59.
As a bonus, the 235 engine turned over by hand.
Just got back from taking it to the shop. i may have a bent push rod. only 13,000 miles since over haul in 2008.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
Now that's a bummer. Let's hope it's a problem with the timing.
~Jim
I hope you are right about the timing, it did start a little funny it was a little reluctant to fire. i am not a mechanic and have not worked on cars or truck for 20 years or more. at idle it sounds fine and even when cruising along but under a little load it makes a knocking sound. also it seems a little under powered.
2017 Buick Encore
See more pix
Today, one of the last sunny ones here in Portland with the rainy season knocking on the door, I did manage to get the right front fender and some other sheet metal off my '46 6400 former farm truck that has moved to the city. Some awful
bad screw locations and old crusty nuts and bolts but all the sheet metal itself is
in pretty darn swell shape. Gonna' be a heap of work! The good kind . . .
Milk the cows you have
I swapped my standard turn signal relay for an led relay so my led taillights will work. I also installed a delay for my courtesy lights.
~Jim
I have a burnt intake valve so far still checking.
2017 Buick Encore
See more pix
1 Offline
Started on my door hinges last night.. got em sandblasted, drilled out, and painted.. before i painted them i mocked them up.. pins are good and tight.. will put them back together with new springs this evening.. It took alot of heat to get the old pins out.. Both pins were broke in half.. also started on the rear cab shackles. got em broke down and all the rubber bushing removed.. will sandblast and paint them tonite.. maybe i can start to fit some of my patch panels for the pass. side tomorrow
Daniel
1953 Chevrolet 3800 Stepside
Worked some disassembly on the '58 donor truck.
I pulled the instrument cluster, seat, vent covers, hood, hood latch, hood latch panel, hood emblem, hood bracing, door panels, radio delete plate with delete plugs, ash tray, glove box lid and latch, igition switch and inside door and window handles.
I labeled and bagged all the bolts and screws... Only twisted off a few.
Sheesh, did I do all that in one evening after getting off work?
You didn't mention pictures! With that much work you should have taken at least 12,623 pictures.
~Jim
I did take a few, only as a reference of how things went together... yep, I tend to "fergit thangs over time".
I'll probably be posting them on my Facebook Album later (This is where I have all my pictures for the '59 project).
Gallery - Facebook Album Link
Made a "custom" rear view mirror mount for the 38. Works and looks great. Should be a lot safer to change lanes now - no more looking over my shoulder !
Fixed the turn signals again, lost an ebay auction for a fender, drove it, then got a flat.
And named it the "bondo bandit" lol
Alex
57' 3100 (The Bondo Bandit)
Bad rust and worse wiring, but so much fun.
Swapped out the generator for an alternator, and replaced just about all the wiring that doesn't power lights or accessories.
1959 Chevy 3/4-ton (pics posted soon)
I child-proofed my house, but my kids keep finding their way back in.
Drove it for the first time. Country road, 70 degrees and Sunshine. Not my first old ride, but truly my favorite. I'm not sure if I was high off the fumes, or just so excited that I finally have a 55'. Either way I'm Hooked.
Get your fix on Route 66 and at the Stovebolt.
~Jim
Took care of and exhaust leak on my manifold
....exhaust leak pic....
Took it to a local machine shop and he decked it for me for $50.00. I thought that was a fair price.
...machined manifold pic...
Got it all back together..
Next project
....THIS!!!!!....
1 Offline
I FINALLY got rid of the 18"s And installed new Tires & Rims WOW I cant get over the ride it has now, The 18" tires & rims sure looked nice on the old truck but rode rough. It's like I got a new Truck !
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
1 Offline
Made some head way on the hood seam. Got all the holes filled, smoothed, bondo and primed. Not bad for a rookie. grin
Pic 1
Pic 2
Pic 3
Pic 4
Pic 5
Man Robert... That really turned out sweet Now you have me looking at mine !
I can only hope it turns out as good as yours.
1bad51, when i look at a lot of trucks and cars today it amazes me what people put on the cars and trucks for looks and don't realize how badly they will ride. i don't know how we got to this point except for the manufactures wanting marginally better gas mileage. i have a PT cruiser and have three sets of tires and none are worth anything in snow. they are 205-50-17, the only way to get better traction and ride is to change tire and wheels to 16s. i have 215-75-15 on the front of my truck and now that i have raised the front suspension i may go to a larger height tire for more cushion over bumps.
2017 Buick Encore
See more pix
Originally Posted by TooMany2count
Front suspension together(less the coil springs), rear suspension has been rebuilt w/new pins & bronze bushings in springs & hangers. It's now at ground level sitting on jack stands waiting for the rear end to be installed.
All thanks to the help I got from Andy, Frog, Pat, Henry and my wife.
If it wasn't for them it wouldn't be this far along.
Thanks wave folks........joe
Joe! The pics Joe, the pics...
~Jim
I made a frame repair - my first ever. Not bragging, just glad people on this forum were willing to teach me how.
Before
http://i618.photobucket.com/albums/tt269/fastboatman29212/65%20Chevy%20C10/DSCN0660.jpg
After
http://i618.photobucket.com/albums/tt269/fastboatman29212/65%20Chevy%20C10/1025111806.jpg
Got the bed torn down completely on my 65. Man what a job! Now onto getting the cab torn down and lift off the chassis!
I mounted the front clip and hood to my 56 GMC.
It much better now.
After adjusting my 54's Hydramatic transmission, I found that my accelerator now sticks. Oh wow!
Disciple
I made an Excel Spread Sheet of tasks for my '59 project.
It can sometimes seem overwhelming and this will help me monitor progress and keep me focussed on the jobs yet to be done, large and small. I told my wife I need to take care of one or several tasks per day.
When I was swapping out a hood latch assembly yesterday, my step daughter said she had faith in me. Fuel for the soul! grin
Finished painting and decaling an oil bath filter that I converted to take a dry element.
Outside:
http://farm7.static.flickr.com/6034/6286049814_ba86c58e94_b.jpg
Inside:
http://farm7.static.flickr.com/6236/6286050234_968eb64773_b.jpg
NICE! thumbs_up
Absolutely the way to go! I usually have general tasks on my sheet then as I get into the I get very specific. I keep a printed copy with me in the shop at all times and when I think of something or plans change I jot it down. Then I update the electronic version and print a new sheet at the end of the week (or sooner if things are really moving!)
Sort of stock 1950 Chevrolet 3100
235 (The engine shread) (Engine assembly)- 4 speed - 12 bolt - stock front axle with power disc brakes
I have a dry erase board on the wall in my garage. On it are listed each mini project left to finish my bolt. Usually I work one project each day/night and then run a line through that project on the board.
~Jim
Removed crusty original bench seat,,removed dash cluster,,started mapping out the rats nest that is the wiring harnass...broke dry rotted inside light cover!!
Visited my '58 donor truck after work, and extracted the passenger door handle, door panel, both door latch assemblies, window trim and stiker plates. I also snagged the horn and battery tray.
The nicest part about it was doing it in a cool rain!
YES to the RAIN!
