1 members (wvstovebolt),
31
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#78927 06/19/2007 1:38 AM | Joined: May 2007 Posts: 37 Apprentice | | Apprentice Joined: May 2007 Posts: 37 | Can some one tell me if it is normal for the rear differential to be off centered on a 72 c100 chassie. I'm not sure if it just because everything is so worn out and the fact that there isn't that much weight on it,but it is about an inch and a half closer to the drivers side than it is to the passenger side. I'd like to know if this is normal or would be fixable with an adjustable panard bar. I'd like to find out before I sink much more into this project, thanks. John | | |
#78928 06/19/2007 3:05 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I've never seen one that far off before. I would get under it with a measuring tape and do some diagnosis. Check the perches to see if some previous owner installed the rear-end off center. Check the panhard bar for straightness. Check the trailing arms for damage and/or rust, etc, Good luck, Scott | | |
