5 members (Gray_Ghost, greenie-reddy, Lostbuthaulinass, HandyAndy, 1 invisible), 161 guests, and 2 robots.
Topics128,108
Posts1,056,237
Members48,437
#787960 10/11/2011 7:55 PM
I am looking for Chevy's door striker Shims (part #3689312) so as to properly align the doors on my 1950 Chevy 1/2 ton pickup. If the shims are no longer available, then I would like to see a specification/drawing sheet with all appropriate dimensions such that I could fabricate same.
Charlie, I have two striker plates left on a cab that I am trashing. If any are behind the striker I can fix you up. Right now its raining cats and dogs so it'll be at least tomorrow ....
unless you come across some sooner.
I see your in Aiken..do you know Steve Bright?? Also expect you at the Southern Stovebolt Reunion next year!!
That is great info.
I am also told that one can use "trash quality" striker plates as shims because you can cut off the top & bottom tabs where the bolts go thru as they are a perfect shim.
Please keep me posted.
Chuck Burhans
2400 Cardigan Drive
Aiken, SC 29803
Home (803) 642-0401
Cell (908) 239-9228
Here is some info off a 51 you can look at
....Woddy's Link....
....Woody's Link....
Some of the door parts changed between 50 and 51 but you should be able to get an Idea on how to make the shim.
Good Luck
