6 members (greenie-reddy, tesa, Shade Baby, asilverblazer, wvstovebolt, 50Chevy3100), 88 guests, and 2 robots.
Topics128,083
Posts1,055,967
Members48,430
Page 2 of 2 1 2
squeeze #787574 10/10/2011 2:06 PM
Figures don't add up. Like the Joker says.your rear end ratio is wrong or the tach is set for a 4 cyl truck.
56srw #1064292 10/24/2014 6:36 PM
I Have a57 Chev Pick up with a327 Engine with a350 Outo Trans what Gear Ratio Rear End do I need
56srw #1064331 10/24/2014 11:37 PM
DE, you "need" a ratio that'll do the job you want to do, you'll never get great gas mileage pushing that brick around with a 327 .... the standard '57 had a 3.90 rear, not bad for general driving, you can haul a load with it - if you're more into highway driving and never use it as a truck, maybe look into Patricks 3.55 rear gear set, or change to a 700R4 to gain overdrive
56srw #1064554 10/26/2014 4:18 AM
my opinion...700R4 since you already have open driveline.....I ended up putting the 700 in both my vehicles after trying the 350 tranny.
.....and maybe a rearend from a Malibu, Monte Carlo, some olds and others.
56srw #1064572 10/26/2014 7:31 AM
You don't mention the size of the truck... 1/2 ton? 3/4 ton? Etc.
Gears depend on tire size and type of driving. Fill in some blanks for us about howmyou will be using your truck, tire size, and how your 327 is built, and we can give you a better answer than a wild guess.
56srw #1064600 10/26/2014 3:03 PM
Hey everyone,
When I fist started to put my tuck together, my intentions was to make it a highway driving truck. With a little home work, a bit of luck, and some kindness of others I'll have it all together soon enough.
If you all don't mind, can ya look over my specs give me a once over?
'39 1/2 ton truck
'54 235 w/single barrel
NWC T5
3:25 rear end (Currie 9")
26" diameter tires (P255/60R15)
Bread
1939 Chevrolet 1/2-Ton
"There and back -- repeat"
56srw #1064698 10/27/2014 1:42 AM
Bread #1064913 10/28/2014 3:01 AM
Originally Posted by Bread
Hey everyone,
'39 1/2 ton truck
NWC T5
Bread
Bread, what is the OD ratio in your T-5?
Carl
56srw #1064973 10/28/2014 1:07 PM
V
V Offline
51 Chevy pickup, 273 gears (70 olds rear)mustang II front, 700r4 & 4.3v6 TBI
consistently get 22 to 23 mpg, runs 2400 to 2600 rpms at 60 mph (depending on the lie of the land)
lots of power to cruise. Very happy with this set up. Kept everything else stock.
vickraft #1065007 10/28/2014 4:22 PM
Since I can all but guarantee you're not running 18" diameter tires something there is wrong. There is no way you would be running 2400-2600 RPM at 60MPH with a 2.73 and 700R4 in overdrive. With that setup your 4.3 would lug like crazy at 60MPH. Something there is off. What's you actual gear ratio and tire size?
With those parameters you would be running at most 1500RPM at 60MPH, assuming a 26" tire.
My 46 GMC on Photobucket
Page 2 of 2 1 2
